Podziękowania Podziękowania:  0
× tak × tak:  0
× nie × nie:  0
Na fronta! Na fronta!:  0
Pokaż wyniki od 1 do 5 z 5
Wątek: Zbrush 2019.1
  1. #1
    Member
    Dołączył
    Jul 2008
    Postów
    1763
    Podziękowania
    Domyślnie Zbrush 2019.1
    Reklama widoczna tylko dla niezalogowanych użytkowników
    https://www.zbrushcentral.com/t/zbru...ailable/216270
    Feature additions
    ZBrush 2019.1 introduces several additions to both improve workflow and enhance your ZBrush experience:
    A new split mode, which isolates the current SubTool from all others, displaying them on separate sides of the screen. See it in action with the video below!
    A Screensaver has been added which (after a predefined amount of time) will display curated images straight from the ZBrushCentral.com 24 community. Unlike your operating system screensaver, this one will only affect the ZBrush application window.
    A new “Groups Intersection” mode has been added to the Smooth Brush Modifiers.
    GoZ has been updated with support for Adobe Photoshop® 2019, Autodesk Maya 2019 and Autodesk 3DS Max 2020.
    The FBX format now supports up to 64 cameras at import and export. Imported cameras are listed in the Camera selection list in the Draw palette. FBX will now support up to FBX 2019.
    Plugins
    Several plugins have been updated to support 2019 additions as well as for stability and performance improvements:
    SubTool Master, with a new Show Hidden Points function.
    ZAppLink
    Scale Master
    3D Print Hub, with better handling of large STL files and support for more STL formats on import.
    Intersection Masker
    FBX Import/Export
    ZBrush to Photoshop
    ZColor
    Decimation Master
    Image Plane
    Improvements
    Below are some of the improvements or behavior changes made with ZBrush 2019.1:
    A pop-up message is now displayed when exiting Edit mode, asking for confirmation.
    SubTool folders now support Move Up and Move Down functions.
    SnapShot 3D with reference images will no longer apply a DynaMesh Boolean process. (Pressing ‘Sub’ is now required for the SpotLight image to be cut out of the DynaMesh surface.)
    Updated keyboard shortcuts for macOS to now create a Folder with Command+F.
    Updated keyboard shortcuts for macOS to go full screen with Command+Ctrl+F rather than creating a new folder.
    Saving and loading files across a network have been improved.
    Stability and Fixes:
    Several issues raised by our users or beta testers have been fixed in the 2019.1 release:
    Ctrl+Shift brushes no longer jump when holding Space Bar.
    Assigning a hotkey now gives a warning if the hotkey is already in use.
    Snapshot 3D snapping points now respects canvas Zoom.
    Support has been added for .jpeg and .tiff image file extensions.
    Total Points Count display has been improved.
    Improved Boolean generation.
    Crease Level slider will update results when Dynamic Subdivision is enabled.
    Dots display mode is now disabled when Transparency mode is active.
    Improved stability of the Surface Noise editor.
    Improved stability when switching rapidly between Edit and Move modes.
  2. #2
    Redaktor
    Złota Galeria Srebrna Galeria 3D Grand Prix
    Dołączył
    Mar 2002
    Lokalizacja
    66-400
    Postów
    9636
    Podziękowania
    Domyślnie
    no ciekaw jestem czy bedzie stabilniej niz ostatnio :) czekalem na ten updacik
  3. #3
    Redaktor
    Dołączył
    Mar 2002
    Lokalizacja
    66-400
    Postów
    9636
    Podziękowania
    Domyślnie
  4. #4
    Member
    Awatar Imperator
    Dołączył
    Sep 2009
    Postów
    550
    Podziękowania
    Domyślnie
    Nareszcie będzie można zaimportować 64 kamery do zbrusha, w końcu, tyle na to czekałem. Teraz zbrush ma już absolutnie wszystko co potrzebne, nie ma na co narzekać :)
  5. #5
    Redaktor
    Dołączył
    Mar 2002
    Lokalizacja
    66-400
    Postów
    9636
    Podziękowania
Uprawnienia umieszczania postów
  • Nie możesz zakładać nowych tematów
  • Nie możesz pisać wiadomości
  • Nie możesz dodawać załączników
  • Nie możesz edytować swoich postów
