Strona 7 z 11 PierwszyPierwszy ... 234567891011 OstatniOstatni
Pokaż wyniki od 61 do 70 z 104
Wątek: Paintstorm Studio
  1. #61
    Member
    Dołączył
    Jul 2013
    Postów
    42
    Podziękowania
    Domyślnie
    Reklama widoczna tylko dla niezalogowanych użytkowników
    Jeśli ktoś jeszcze nie kupił, a chciałby to teraz może być dobry moment, bo z okazji black friday jest obniżka 50%.
    artstation: http://goo.gl/OQMJNA ....*****.... facebook: http://goo.gl/idqXsU
    deviantart: http://goo.gl/RJqXGP ....*****.... teczka: http://goo.gl/VdOKdb
  2. #62
    Member
    Awatar Imperator
    Dołączył
    Sep 2009
    Postów
    550
    Podziękowania
    Domyślnie
    Tradycyjnie już przypominam o tej perłce :) nowa wersja, nowa strona, nowa prezentacja :) ale cena stara tj 19$! nie wiem jak oni mogą to nadal za pół darmo rozdawać :)
    http://www.paintstormstudio.com/
    VERSION 1.55 (22.04.2016)
    - A new feature to record/playback the process of drawing called Script added.
    Typically, the scripts are used to create videos of a painting process, however with Paintstorm's script it is possible to increase the canvaz size of your pics without any quality loss.
    Learn more about Script here: http://paintstormstudio.com/help.html#SCRIPTR
    - "Toggle rulers" hotkey added
    - "Lock interface" button added (top right corner of the Paintstorm window)
    - Some small bugs fixed
    VERSION 1.54 (19.03.2016)
    - A new «Blur» parameter of the brush added that affects the strength of the paint mixing
    - An ability to select layers in Photoshop style from the drop-down list (by default - Mouse Rightclick)
    - An ability to move the layer with keyboard arrows added
    - An option "Show / Hide brush circle" in Menu-> Options added
    - An ability to display the «Thumbnails with layer bounds» added to the options of the "Layers" panel
    VERSION 1.53 (01.03.2016)
    - New "Ruler" feature added: Parallel lines, Ellipse, 2-point perspective, 3-point perspective
    - "Global pen pressure hardness" feature added to Menu-File-Options
    - The ability to "Merge all lower layers to one new" added (ctrl+alt+shift+e or from menu)
    - The ability to Apply mask added
    - A bug of saving PNG with alpha chanel fixed
    - "Rename brush" item added to the Brushes options
    - The Free Transform option moved to Menu-Edit from Menu-Image
    - New interface language added:French (Thanks to Siron Jean for translation)
    VERSION 1.52 (07.02.2016)
    - The new "Real Double brush" feature added. Now you can paint with two brushes simultaneously instead of using the second brush only as a mask. You can also synchronize main parameters of both brushes.
    - We added the ability to shift the pivot point for custom forms. It is also possible to reflect the shape vertically or horizontally and rotate at any angle.
    - New buttons added to the top «Tool options» panel: free transform, disable selection, chain for rect selection and free transform, etc.
    - Now, when you close the last file, Paintstorm creates a blank canvas without shutting down.
    - Instead of "rightclick" an additional button added to the following panels: Gradients, Textures, Brush icons, Brush Group icons, Custom Forms.
    - «Move the layer up / down» buttons added to the «Layers» panel
    - Presets added to the File->New panel
    Ostatnio edytowane przez Imperator ; 27-04-16 o 16:36
  3. #63
    Member
    Awatar Imperator
    Dołączył
    Sep 2009
    Postów
    550
    Podziękowania
    Domyślnie
    Kolejny raz przypominam tym co kupili i nie używają :)
    W wersji 1.7 dodali jedną przydatną funkcje - można transformować lub "liquifajować" wiele warstw lub zaznaczonych fragmentów z warstw jednocześnie, to o jedną przydatną funkcję więcej niż adobe dodało w nowym photoshopie :D
    VERSION 1.71 (16.10.2016) - HOT FIX
    - Fixed an issues and bugs of version 1.70
    - New "Fast layer move" hotkey added
    - New "Show\hide reference layer" hotkey added
    VERSION 1.70 (12.10.2016)
    - An ability to select multiple layers and do the followings with them added:
    layers move, free transform, swap layers, delete layers, collapse layers, delete selection, preserve opacity, lock, warp filter.
    - A new Warp filter added
    - New types of gradients added: radial, symmetry, circle
    - Flip horizontal / vertical layers functions added (Menu->Edit)
    - An ability to enable / disable the link (chain) between the layer and mask
    - Added a function of layer duplication by holding Alt
    - Added the ability to move the layer while holding Ctrl
    The following bugs fixed:
    - An burn effect at low transparency fixed
    - A bug of trembling form when "form shift" fixed
    - A bit of memory is released at the time of saving / loading psd
    - A "lock of transparent pixels when blend transparency is on" bug fixed
    - Some minor bugs fixed
    VERSION 1.61 (24.08.2016)
    - «Select by color range» function added. With this accurate tool you can easily select a specified color or the range of color and brightness.
    - Improved quality and accuracy of "Free transform" and "Image resize" tools
    - Improved quality of selection edges when using "Straight lasso" tool
    - Some little bugs fixed
    VERSION 1.60 (18.05.2016)
    - The "Clone" tool added. Find the button close to the "Eraser" button in the "Brush" panel.
    - The cursor shape changed: now it has the same shape as the brush instead of the circle.
    - A new "Resolution (dpi)" option added to the following panels: "New file", "Image resize" and "Canvas size". The dpi value is now saved in PSD files.
    - A new "Filters " section added to the menu . This section contains two filters - "Blur" and "Sharpen".
    - The active box to control the position of the canvas added to the "Navigator" panel.
  4. #64
    Member
    Dołączył
    Jul 2008
    Postów
    1763
    Podziękowania
    Domyślnie
    Nie za pół darmo tylko za darmo, bo płącisz raz na całe życie. A 19 baksów i i gimnazjalista wydłubie od starcyh ;)
    Aż mnie korci żeby to sobie kupić i nie używać :P Tak zrobiłem z Mischief i to był strzał kulą w płot. Po za pierwszymi ochami, achami i ojeku, soft został przeze mnie zapomniany, jak równiż przez developerów.
    Ale ten wygląda bombowo, z każdą wersją! Na razie siedzę przy Kricie a wątek obserwuję.
  5. #65
    Been Through the Mill
    Awatar Nezumi
    Dołączył
    Oct 2006
    Lokalizacja
    Toluca, Mexico
    Postów
    4568
    Podziękowania
    Domyślnie
    O nie widzialem, ze tak preznie promujesz ten kapitalny sofcik tutaj ;) Ostatnio zassalem sobie od nich zestaw brushy udajacych olowki i jestem zachwycony. Lepiej to mi tylko normalne olowki "dzialaja" :D Bardzo sie ciesze ze kiedys skozystalem z tej promocji i kupilem za pare groszy to cacko! Dzieki za linki do filmikow!
    “There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.”
    ― Ernest Hemingway
  6. #66
    Member
    Dołączył
    Jul 2008
    Postów
    1763
    Podziękowania
    Domyślnie
    Dobra, namówiliścnie mnie. Zgłoścnie się do nich po prowizje.
    Nie wiecie o co chodzi w Paintstorm Studio
    SPECIAL PRICE
    FOR THE FIRST 1000 ARTISTS
  7. #67
    Awatar Nezumi
    Dołączył
    Oct 2006
    Lokalizacja
    Toluca, Mexico
    Postów
    4568
    Podziękowania
    Domyślnie
    Cytat Zamieszczone przez michalo Zobacz posta
    SPECIAL PRICE
    Ta, dalej ta sama, promocyjna cena jest, choc przypuszczam, ze juz dawno sprzedal wiecej niz 1000 kopii ;) Nie zastanawiaj sie, jak lubisz soft do digital paintingu to sie nie zawiedziesz.
    ― Ernest Hemingway
  8. #68
    Member
    Awatar Imperator
    Dołączył
    Sep 2009
    Postów
    550
    Podziękowania
    Domyślnie
    Cytat Zamieszczone przez Nezumi Zobacz posta
    O nie widzialem, ze tak preznie promujesz ten kapitalny sofcik tutaj ;) ...
    Trzeba ludziom przypominać, że są całkiem przyjemne alternatywy zwłaszcza za tak małe pieniądze :) Poza tym gdybym sam nie był tak bardzo zadowolony z painstorma to bym o nim nie trąbił a o niewielu softach mogę to powiedzieć, chyba najlepiej wydane 19 dolców w życiu nawet gdyby mieli już przestać go rozwijać :)
  9. #69
    Member
    Dołączył
    Jul 2008
    Postów
    1763
    Podziękowania
    Domyślnie
    Jest super. Idealnie współpracuje z wacomem, bardzo dynamiczne i płynne UI. Myślę, że to jeden z najprzyjemniejszych softów jakie widziałem. Daje podobne wrażenie jak porówannie działania Afiniti Designera do illustratora lub ColrelDrawa (mówię o płynności działąnia)
    Jeśli ktoś maluje a się zastanawia to polecem.
    Mam nadziję, że zapracowałem na swoje ołówki :P
  10. #70
    Member
    Dołączył
    Jul 2007
    Postów
    625
    Podziękowania
    Domyślnie
    Imperator - rok temu pokazałeś ten soft na forum, dzisiaj kupiłem:) mam nadzieję ze chociaż raz użyję. Ten soft ma ogromne możliwości...obejrzałem tutki, przejrzałem forum - nie było co zwlekać:) dzięki!
    http://trzyde.blogspot.com/ - modele 3D, drzewa i ludzie z kanałem alpha, tutoriale,
Uprawnienia umieszczania postów
  • Nie możesz zakładać nowych tematów
  • Nie możesz pisać wiadomości
  • Nie możesz dodawać załączników
  • Nie możesz edytować swoich postów
