realflow -3ds 7 plug
  • Odpowiedzi 1
  • Wyświetleń 1,3k
Hi all,
is there a new plugin package for 3ds Max 7 ?
if i can use 6 plugins with 7, how do i install these plugin. already tried downling the files to the plugin folder and Max 7 doesn't see them.
or maybe im missing a step, can't seem to find instructions on how to install them.
thanks
na to drugi koleś
Check your plugin.ini file with notepad to see if it lists your plugin directory, it should already though. Just be careful you don't have two copies of the same file inside your plugin directory or it will cancel the other one too.
It should be just as simple as extracting the plugin files to your (max root)\plugin folder. Then restart max and it should have a Next Limit object under Geometry.
spróbuj. pozdrawiam.
