słownik tego całego żargonu
właśnie szukam (jak dotąd bez efektu) słownika jakiegoś, bo jak czytam tuta to często jest jakieś określenie którego nie czaje, czy ktoś wie może gdzie to znaleźć ?? z góry thx
  • Odpowiedzi 1
  • Wyświetleń 1,5k
standardowy help Max\'a :]
np.
MeshSmooth
The MeshSmooth modifier smoothes geometry in your scene by adding faces at corners and along edges. The effect of MeshSmooth is to round over corners and edges as if they had been filed or planed smooth. When you apply MeshSmooth, an extra face is added for every vertex and edge. Use MeshSmooth parameters to control the size and number of new faces, and how they affect the surface of the object.
You can use MeshSmooth to produce a Non-Uniform Rational MeshSmooth object (NURMS for short). A NURMS object is similar to a NURBS object in that you can set different weights for each control vertex. You can further control the object\'s shape by changing edge weights.
MeshSmooth\'s effect is most dramatic on sharp corners and least visible on rounded surfaces. Use MeshSmooth on boxes and geometry with crisp angles. Avoid using it on spheres and similar objects.
Tip: To better understand MeshSmooth, create a sphere and a cube and apply MeshSmooth to both. The cube\'s sharp corners become rounded, while the sphere\'s geometry becomes more complex without changing shape significantly.
Note: Having an animated deformer placed before a meshsmoothed object that has had control level editing can result in the meshsmoothed object becoming distorted. It\'s recommended that deforming modifiers be placed after the MeshSmooth modifier in the stack if you\'re using the deformers for animation.
a jeśli nie zabardzo kumasz angielski tak jak ja :)
to po obrazkach dojdziesz :)
