MAXWELL 1.2 i MAYA 6.5
Zainstalowałem plugin maxwella pod mayę ale wyskakuje jakiś błąd:
Registering Mayall Plug-In (Version: 0.8.9(Beta)) ...
MXS Translator loaded
Maxwell Globals loaded
Maxwell Environment loaded
mayall command loaded
Maxwell Materials loaded
Maxwell Objects loaded
Mayall Tools loaded
Error initializating Mayall, check your installation
i plugin się nie ładuje
  • Wyświetleń 2,5k
variable- jak?
oto odpowiedź:
Mayall Windows InstallationIn this chapter you can get information about how to install Mayall in a Windows System
You can setup and get Mayall running in a few steps
  • Uncompress the fileMayall_071.zip in c:\.
  • You need to setup several enviroment variables, in order to do it:
    • go to: Start -> Control Panel -> System
    • Into the System dialogue look into the Advanced Tab, Click on Enviroment Variables.
    • If you a re installing the Plug-In for all the users use System Varibales, if you are installing only your user you can use User Variables too.
    [*]Setup the next variables:
    • MAYA_PLUG_IN_PATH = c:\mayall
    • MAYA_SCRIPT_PATH = c:\mayall
    • XBMLANGPATH = c:\mayall
    • MAYALL_ROOT = c:\mayall
    [*]The Maxwell install program must set you enviroment variable MAXWELL_ROOT to the Maxwell install dir, check it. If it doen's exists create your own MAXWELL_ROOT variable pointing to your Maxwell install dir, for example: if Maxwell isinstalled in c:\maxwell, set the enviroment variable to this path.
    [*]Launch Maya and go to: Windows -> Settings/Preferences -> Plug-In Manager
    [*]Go to c:/mayall folder and select mayall_maya60.mll for Maya 6.0 or mayall_maya65.mll for Maya 6.5 .
    [*]Click on Load and Auto Load if you want that Mayall will be loaded every time Maya is launched.
    [*]If you click on the Info button on the right tou can see the Mayall version.
    [*]Enjoy Maxwell!
    [*]ADVANCED: if you want to install Mayall in other location different than c:\mayall, you only need to substitute the c:\mayall path used before by your new mayall installation path.
dzięki wielkie... teraz działa, kto by się spodziewał, że to takie proste będzie :)
