na tej stronie jest tutorial dot maski samochodu.
http://www.onnovanbraam.com/index.php?m=tutorials&g=7-car-body
Nie rozumiem tego w pewnym stopniu:
I now will model the headlights and the crease of the hood. Since the headlights look to be perfectly smooth with the body I will just make creases around it (and not delete them and later on try to remodel them back in). And with one sweep I will also create the crease of the hood. So I select the edges (1) I want to crease and apply the technique explained in an earlier tutorial (2). With a 2 iterations MS modifier (3).
jak zrobic te grube czarne linie??
  • Wyświetleń 761
znajdź ten tutorial i tam powinno być napisane
zapewne chodzi o chamfer
