VRay 1.09.03h released
New features and bug fixes
Fixed a bug that could cause crashes when manipulating objects in the viewports after rendering with VRay and other anomalies in 3dsmax.
Added an Affect alpha parameter to VRayMtl; this will cause the alpha channel to be taken from the things that are seen through the material when using refraction. Note that this only works for non-glossy refraction (refraction glossiness set to 1.0).
Fixed a bug that caused objects excluded from illumination by VRayLights to be illuminated when the lights\' Store with irradiance map option is on.
Added another color mapping mode, called HSV exponential; it is very similar to the Exponential color mapping mode, but will preserve the hue and saturation of colors, and will only limit their value.
  • Wyświetleń 1,5k
