Alias wydał darmową poprawkę dla maya 7
[link]
Upgrade zawiera
Maya 7.0.1
The DwgTranslator plug-in is no longer distributed with this release. This plug-in provided import and export of DXF and DWG files.[238832]
DXF files have been associated with the FBX plug-in by default. The FBX plug-in can import AutoCAD Drawing Exchange Format Version 13 (.DXF).
Please visit our Conductor partners for other options for importing and exporting DXF and DWG:
www.alias.com/io_conductors Maya 7.0P08
  • Fixed a problem with MFnMesh::getTriangles crashing.[240120]
  • Fixed a problem with creating a clip on a reference file.[240521]
  • Fixed a problem with the CgFx plug-in preventing batch renders from working properly.[238397]
  • Fixed a problem with display of non-square textures.[239399]
Maya 7.0P07
  • Fixed a problem with window resizing in a dual screen setup.[239828]
  • Fixed a problem with being unable to render to any format other than iff.[239396]
  • Cgfxshader doesn't release texture memory.[240054]
  • Fixed a problem with duplicate namespaces being lost in referenced files.[240032]
  • export selection will export everything in a parent scene with references.[231531]
  • The loss of locked/hidden state when child is reference twice.[240063]
  • Surface sampler creates some non-smooth uv boundaries.[240462]
  • large increase in file load/save times when using referencing.[232357]
  • Playblast off screen doesn't work{linux only}.[237580]
  • transparent lines overlap non-transparent lines.[234731]
  • Surface sampler does not correctly sample bump maps.[240571]
  • deformer sets corrupted after delete non-skin deformer.[240067]
  • Toon effect (paint fx) causes intersections through surfaces.[239650]
    In order to support this functionality some new attributes were added to the pfxToon node:
    Long name (short name) Type Default
    localOcclusion (lcl) enum 0
    If Line Surface is used then lines will be clipped where they are hidden by the surface they are created from. If All Toon Surfaces is used then lines will be clipped where they are hidden by any of the surfaces that are currently assigned these toon lines. This occlusion is generally meant to augment the line occlusion by the normal paint effect render, or orther renders if convert toon to poly is used. With paint effects renders, the depthBias attribute may be useful when combined with local occlusion.
    occlusionTolerance (otl) double 0.01
    This is an amount in worldspace that lines are moved towards the camera when testing depth for local occlusion. A small value is required to avoid artifacts where the surface self occludes lines.
    depthBias (dbs) double 0.0
    This is an amount in worldspace that lines are moved towards the camera when rendering. This is useful in avoiding artifacts with depth occlusion by the surface the lines are on.
    backfacingCreases (bfc) bool true
    If on, then creases are generated on surfaces that face away from the view.
Maya 7.0P06
  • Fixed a problem with "Delete Unused Nodes" removing shaders still being used.[239222]
  • Fixed a problem with being unable to export multiple characters to fbx.[238074]
  • Fixed a problem with being unable to read back color set data.[235080]
  • Fixed a problem with Render -vr -im not working.[239306]
Maya 7.0P05
  • Fixed a problem with RMB menu over joints locking the joints.[236028]
  • Fixed a problem on file open where CV tweaks were not applied to NURBS curves in files referenced multiple times until references were reloaded.[238112]
Maya 7.0P04
  • Fixed a problem with the "Match Render Tessellation" option in NURBS to Polygons not producing the same results as those shown when using "Display Render Tessellation" on the NURBS surface. The problem occurred in two circumstances:[237946]
    • when the Edge Swap option was disabled
    • when the transform node for the NURBS surface had non-unit scaling
    [*]Fixed a problem with rendering fur with a non-unit aspect ratio not rendering properly.[238204]
    [*]Fixed a problem with Reverse Fur Normals not behaving properly.[238119]
    [*]Exporting objects (either all objects, or Selected ones) with the Preserve References option enabled would produce a corrupt file, and make Maya unstable.[237452]
Maya 7.0P03
  • Fixed a problem with mental ray framebuffers not being obeyed.[237129]
  • Fixed a problem with render -preRender not handling "'s properly.[237125]
  • Fixed a problem with mrBatchExport not setting -xp.[228959]
  • Fixed a problem with painting attributes leading to a crash.[237476]
  • It is sometimes possible for Maya's vector renderer to generage SVG files that do not render properly in certain SVG readers, e.g. Adobe Illustrator. These files exhibit color bleeding in areas of the vector output. The bleeding is a result of the winding direction of certain vector polygons with holes.[233348]
Maya 7.0P02
Fixed a problem where API MEL commands which called MGlobal::executeCommand could crash Maya. Commands which did not provide a newSyntax callback when registering the command could crash when multiple calls to the command were executed from within the same block of MEL code. eg. if two calls to the command were executed from within the script editor at the same time.[236674] Maya 7.0P01
  • Fixed a problem with render -r mr ignoring -rd.[235788]
  • Fixed a problem with the Surface Sampler generating empty pixels in the output image when the image height was set greater than the image width.[236835]
  • When painting skin weights, where the weight of a vertex has been held by a joint, if another joint was added as an influence to that vertex, the vertex would go to the origin if the weight is over 1.[229941]{linux only}
  • Crash or corruption when opening a scene with references. The corruption noticed was causing extra namespaces to appear: if a scene contained a single reference “ref.ma” in the namespace “ref”, opening the scene and executing ‘namespaceInfo –lon’ might show two namespaces “ref” and “ref1”. There is no well defined workflow to cause this crash, however it has only been known to occur in a scene with references where one or more of the referenced files contain softMods.[235202]
  • Fixed a problem with Remove Selected not working properly.[234472]
  • Crash when using Isolate Select in a scene containing references. The workflow for hitting this bug is fairly involved, so typically customers who encountered it were not able to pinpoint Isolate Select as the cause. The most common reported symptom was “occasional crashing when working with a scene containing references”.[233849]
    Example:
    1. New file. Create a cube. Save as cube.ma.
    2. New file. Create a sphere. Save as sphere.ma.
    3. New file. Reference cube.ma. Reference sphere.ma.
    4. Unload sphere.ma.
    5. Isolate Select the cube.
    6. Load and unload sphere.ma.
    7. Save as top.ma.
    8. Toggle Isolate Select off.
    9. Load the sphere.
    10. Save... crash
Please note
  1. Please install this patch release Update only if you believe that it may fix an identified problem with your software.
  2. THIS UPDATE IS PROVIDED "AS IS". NO WARRANTIES, EXPRESS, IMPLIED OR ARISING BY CUSTOM OR TRADE USAGE ARE MADE, AND ANY IMPLIED WARRANTIES OF TITLE, NONINFRINGEMENT, MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE ARE SPECIFICALLY DISCLAIMED.
  3. By downloading the Update you acknowledge your understanding that the Update is provided subject to the terms of your currently existing Membership Services Agreement.
  • Odpowiedzi 1
  • Wyświetleń 1,7k
