Błędy przy odpalaniu 3d maxa 2009
Dostaje taki log w oknie Mental Ray
LINK 0.0  progr: module #5 (.\shaders_standard\shaders/subsurface.dll) loaded
LINK 0.0  progr: module #6 (.\shaders_standard\shaders/3dsmaxshaders.dll) loaded
LINK 0.0  progr: module #7 (.\shaders_standard\shaders/3dsmaxhair.dll) loaded
LINK 0.0  progr: module #8 (.\shaders_standard\shaders/paint.dll) loaded
LINK 0.0  progr: module #9 (.\shaders_standard\shaders/architectural.dll) loaded
LINK 0.0  progr: module #10 (.\shaders_standard\shaders/production.dll) loaded
LINK 0.0  progr: module #11 (.\shaders_standard\shaders/mayabase.dll) loaded
LINK 0.0  error  191007: cannot load .\shaders_standard\shaders/adskshaders.dll, unknown error code -1073741795, check Win32 manual
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 8: while defining declaration "adsk_uvsetid_translator": declaring nonexisting function adsk_uvsetid_translator
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 21: while defining declaration "adsk_environment": declaring nonexisting function adsk_environment
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 46: while defining declaration "adsk_texture_placer": declaring nonexisting function adsk_texture_placer
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 58: while defining declaration "adsk_texture_lookup": declaring nonexisting function adsk_texture_lookup
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 71: while defining declaration "to_bw": declaring nonexisting function to_bw
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 83: while defining declaration "adsk_scale_meters_to_internal_inverse": declaring nonexisting function adsk_scale_meters_to_internal_inverse
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 94: while defining declaration "adsk_scale_meters_to_internal": declaring nonexisting function adsk_scale_meters_to_internal
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 105: while defining declaration "adsk_scale_internal_to_meters": declaring nonexisting function adsk_scale_internal_to_meters
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 121: while defining declaration "adsk_decal": declaring nonexisting function adsk_decal
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 132: while defining declaration "adsk_blurred_reflection_multiplier": declaring nonexisting function adsk_blurred_reflection_multiplier
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 143: while defining declaration "adsk_blurred_refraction_multiplier": declaring nonexisting function adsk_blurred_refraction_multiplier
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 155: while defining declaration "adsk_aspect_ratio_height_per_width": declaring nonexisting function adsk_aspect_ratio_height_per_width
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 167: while defining declaration "adsk_aspect_ratio_width_per_height": declaring nonexisting function adsk_aspect_ratio_width_per_height
API  0.0  warn   302004: .\shaders_standard\include/AdskShaders.mi, line 177: while defining declaration "adsk_area_shadow_samples": declaring nonexisting function adsk_area_shadow_samples
API  0.0  warn   302004: .\shaders_standard\include/adsk_Utility_Shaders.mi, line 76: while defining declaration "adsk_Utility_MultiMixer": declaring nonexisting function adsk_Utility_MultiMixer
API  0.0  warn   302004: .\shaders_standard\include/adsk_Utility_Shaders.mi, line 860: while defining declaration "adsk_Utility_TexLookup": declaring nonexisting function adsk_Utility_TexLookup
API  0.0  warn   302004: .\shaders_standard\include/adsk_Utility_Shaders.mi, line 931: while defining declaration "adsk_Utility_BumpLookup": declaring nonexisting function adsk_Utility_BumpLookup
API  0.0  warn   302004: .\shaders_standard\include/adsk_Utility_Shaders.mi, line 2273: while defining declaration "adsk_Utility_LightmapSwitcher": declaring nonexisting function adsk_Utility_LightmapSwitcher
API  0.0  warn   302004: .\shaders_standard\include/adsk_Utility_Shaders.mi, line 2311: while defining declaration "adsk_Utility_ColorCorrection": declaring nonexisting function adsk_Utility_ColorCorrection
API  0.0  warn   302004: .\shaders_standard\include/adsk_Utility_Shaders.mi, line 2451: while defining declaration "adsk_Utility_color_to_bool": declaring nonexisting function adsk_Utility_color_to_bool
API  0.0  warn   302004: .\shaders_standard\include/adsk_Utility_Shaders.mi, line 2478: while defining declaration "adsk_Utility_bool_to_int": declaring nonexisting function adsk_Utility_bool_to_int
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 114: while defining declaration "adsk_Shd_WallPaint_spider": declaring nonexisting function adsk_Shd_WallPaint_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 147: while defining declaration "adsk_Shd_Mirror_spider": declaring nonexisting function adsk_Shd_Mirror_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 240: while defining declaration "adsk_Shd_Concrete_spider": declaring nonexisting function adsk_Shd_Concrete_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 311: while defining declaration "adsk_Shd_Hardwood_spider": declaring nonexisting function adsk_Shd_Hardwood_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 374: while defining declaration "adsk_Shd_Water_spider": declaring nonexisting function adsk_Shd_Water_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 491: while defining declaration "adsk_Shd_Metal_spider": declaring nonexisting function adsk_Shd_Metal_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 559: while defining declaration "adsk_Shd_SolidGlass_spider": declaring nonexisting function adsk_Shd_SolidGlass_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 631: while defining declaration "adsk_Shd_Ceramic_spider": declaring nonexisting function adsk_Shd_Ceramic_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 676: while defining declaration "adsk_Shd_Glazing_spider": declaring nonexisting function adsk_Shd_Glazing_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 729: while defining declaration "adsk_Shd_MetallicPaint_spider": declaring nonexisting function adsk_Shd_MetallicPaint_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 794: while defining declaration "adsk_Shd_Stone_spider": declaring nonexisting function adsk_Shd_Stone_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 854: while defining declaration "adsk_Shd_MasonryCMU_spider": declaring nonexisting function adsk_Shd_MasonryCMU_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 911: while defining declaration "adsk_Shd_Fabric_spider": declaring nonexisting function adsk_Shd_Fabric_spider
API  0.0  warn   302004: .\shaders_standard\include/adsk_Mtl_Spiders.mi, line 971: while defining declaration "adsk_Shd_PlasticVinyl_spider": declaring nonexisting function adsk_Shd_PlasticVinyl_spider
ktoś wie gdzie leży problem ?
wrzuciłem kawałek loga w google i wygoglowałem coś takiego
Make sure the 32 bit and 64 bit versions are not installed in the same directory.
ale ja nie mam wesji 64 bitowej...
Problem rozwiązany tu macie link jak by co
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13387381&linkID=9241177
Edytowane przez Azgaroth
  • Wyświetleń 1,1k
