[Blender] Pomoc przy angielskim tutorialu baked shadows na stadionie do gry
Na początek witam wszystkich, którzy to przeczytają :)
Mam problem z angielskim tutorialem o cieniach na stadionie. Nie chodzi o sam język bardziej o to jam mam to zrobić.
here`s a short bake tutorial thanks to alegor for teaching me
download blend file http://www.mediafire.com/?ifag0mbw1t684c3
import stadiums with addboards in sie and then export it open this blend file import the stadium
and now you have to make these settings in all these files expect REBOUNDS
Ztransp, RGB to 0.000, and Trashado
and also Alpha, Anti premul you make it for addoards till to the goals(from ADS_1-00-03 === ADS_1-05-04
then base ,downside,downtribune,field1,field3,left_side and so when you finish all
so now you have to make some parts invisible coz during the bake they make black parts in pitch
make BASE invisible
lines
adverts
dirty parts
rebounds
sky
then make a circle around the stadium holding CTRL Then Object --> Make Links --> To Scene
then save this File Save As in desktop or somewhere you want
ok now we want to bake the pitch
select Field1 then switch to Edit mode make a circle around the stadium holding CTRL
then F9 UV Texture NEW and name it as shad
then go to UV image Editor then pres image
make Width 2048 Height 1024 its standart for pesturfs but you can make also 2048 like in pic
dont forget Alpha 0.000 and press OK
then go to UVS --> unwrap
and the pitch is ready to bake press f10 and press bake and pitch will be baked
when its finished press f9 and delete The first uv texture UVtex ,then go to Image pack image as png
then press f6 and load the new image in desktop pic will be loaded
now select again field1 object make links to scene --> Stadium DF and now export stadium to sef
import with sie and its finished :D
Jeśli ktoś byłby chętny pomóc to daję plik sef i skrypty:
Skrypty http://www.mediafire.com/?dlaznfbpzfsbntc
Stadion http://www.mediafire.com/?1fnnd9h697a0ab4
Jeśli ktoś ma czas i chęci to bardzo proszę o objaśnienie tego tutoriala w języku dla początkujących :)
  • Wyświetleń 2,6k
