Update V-ray 2.50.01 dla 3ds max
Po wcześniejszym ukazaniu się V-ray v.3.0 dla 3ds max 2015 . przyszła kolej na update poprzedniej wersji 2.40.04 . Jest już ona do ściągnięcia ze strony chaosgroup.com - nymer oficjalnej wersji to 2.50.01 .
Build 2.50.01 (official) (14 May 2014)
Lista zmian i poprawek :
(*) Support for 3ds Max 2015;
(*) VRayProxy: Support for Alembic 1.5;
Modified features:
(*) VRayMultiSubTex: Added an option to preserve the alpha of the sub-textures;
(*) VRayProxy: Make the "Animation offset" parameter animatable;
Bug fixes:
(*) V-Ray loses its license when RPManager is running;
(*) V-Ray RT: Do not export SettingsCurrentFrame in .vrscene files;
(*) V-Ray RT GPU: Fixed crash with static geometry rendering;
(*) VRayCarPaintMtl and VRayFlakeMtl: Wrong material name in info message in 3ds Max 2013 and later;
(*) VRayDisplacementMod: Fixed a very slow rendering when Noise texture with animated parameter was used;
(*) VRayDistanceTex: Setting tex_inside_separate_on:true for a VRayDistanceTex constructor from MaxScript causes system exception;
(*) VRayExtraTex: Cloning VRayExtraTex element didn't clone the include/exclude list;
(*) VRayIES: Fixed a rare crash when loading scenes with VRayIES;
(*) VRayIES: Fixed crash after VRayIES light was created in 3D snap mode and 3ds Max was Reset;
(*) VRaySphereFade: Could not edit the gizmo objects list through MaxScript;
(*) VRayToon: Could not edit the exclude list through MaxScript;
(*) VRayLightMtl: Fixed random lighting between renderings with DirectIllumination and CompensateExposure on;
(*) Fixed truncated error messages in the V-Ray log for missing textures in 3ds Max 2013 and later;
(*) Increase the max stdio file handles to the maximum possible (2048) on 3ds Max startup;
(*) Some bake elements has duplicate class names of other plugins;
(*) The V-Ray caustics Auto save option is errorneously named casutics_autoSave in MaxScript;
(*) VRScene exporter didn't work for SSS2 materials;
Edytowane przez WIERZBA
  • Wyświetleń 1,2k
