USB driver dla Motorola c550
kupiłem właśnie taki model telefonu i po przyjeździe do domu z Zarzenowaniem stwierdziłem, że nie ma fizycznej możliwości skomunikowania telefonu z komputerem z powodu braku sterowników.
hmm, po co więc w telefonie gniazgo USB ?
Czy ktoś ze 'szczęśliwych' posiadaczy tego modelu telefonu poradził sobie z tym problemem, albo słyszał coś o tym ?
  • Odpowiedzi 8
  • Wyświetleń 5,1k
I did, but it shows NOTHING !
przynajmniej nic co działa.
Just though I’d write a little guide for win XP cannot comment about other OS’s to help people connect to there C550’s Step 1) Get the cable which is just a bog standard mini USB cable (the one that most digital camera’s use) it will cost about £4.00 from any half decent P.C shop Step 2) Get the correct software & drivers P2K USB drivers & the P2KMAN software…..Both are available here…www.motclub.com its Spanish but very easy to choose programs from the left hand side bar which leads you to the download page. Step 3) Install the drivers……..Plug your phone in once windows dialog box appears asking for drivers choose advanced and point it to the unzipped P2K USB drivers…Next launch the exe from P2KMAN a dialog box will appear saying unable to connect that’s ok, when XP asks for the drivers point it to the unzipped P2KMAN folder it will install about 5 different items individually, once everything’s installed ok launch P2KMAN exe. Step 4) Using the software…….P2KMAN isn’t the most beautiful looking GUI but it does the job to download pictures look in the explorer bar on the right /a/mobile/pictures/ click on the picture you want to download then click yep you’ve guessed it download save it where ever you like, to upload a picture in the rectangle text box on the bottom left type “/a/mobile/picture/” then press upload choose picture gif or jpeg that’s it picture’s are very easy to manage……Now ringtones are just as easy but require a little more tweaking to get them to set as you actual ringtone….type “/a/mobile/audio/” choose upload select required midi file & the tone will appear in sounds but will not be audioable as ringtone, this is because the C550 uses a data base file to manage ringtones & just because you have just stuck the file in the right place it doe’snt been that all the internal links/commands are correct…So what you have to do delete“/a/mobile/MyToneDB.db” (sounds a little scary but these are the things that need to be done for free ringtones) You can download your original database file if you like before deleting but there is no need you phone will create a new one upon reset. Once you’ve deleted the MyToneDB.db you’ll have to reset your phone either buy turning it of for a while or which I prefer remove battery for about 2 minutes then replace your phone will now have rebuild you MyToneDB.db to include your ringtones so they will now work as your ringer. Good luck
:f ju ar lejm ?
:F ar ju ?
jak napisałem wyżej, nic co działa. to są drivery pod xp... ja używam 2000
nie napisałem też, ze uzywam xp :D
tak czy siak, czas najwyższy zmienić system, ta sprawa mnie tylko zmobilizowała.
format c: /FS:NTFS ;)
Dzięki za odzew. Pozdrawiam.
