wings 0.98.27 is out
Release Name: 0.98.27
Notes:
- New command: Hide in the face pop-up menu. Hides the selected faces. Use Show All in the body pop-up menu to show all faces again.
- Trying to edit UV coordinates for an object that was only partially UV-mapped would cause a crash.
- AutoUV no longer causes a hard crash of Wings when there is problem in starting it.
- If there were hidden lights in the scene (without any selection), saving would cause a crash. (Problem reported by Vagabond.)
- Better handling of degenerate faces (such as the face obtained by insetting a face 100%) to avoid hard crashes. (Problem reported by 3D Martin.)
- Trying to UV-map only faces having the hole material would cause a crash. Changed to show an error dialog instead. (Problem reported by Jide.)
- Corrected Grow Edge Loop so that it no longer inccorrectly adds virtual mirror edges to the selection. (Problem reported by xr4y.)
- OBJ files from ZBrush 2 can now be imported. (Thanks to Leif Buckley.)
- For some complex selection boundaries, Dissolve (for faces) would refuse to do its work, instead showing an error dialog box. Corrected.
  • Odpowiedzi 1
  • Wyświetleń 1,1k
