skrypt tworzacy pudelko - problemy
mam taki skrypt (pierwszy napisany przez siebie metoda prob i bledow :/) :
vert_array = #()
face_array = #()
v1 = [0,0,0]
[0,0,0]
v2 = [1,0,0]
[1,0,0]
v3 = [1,1,0]
[1,1,0]
v4 = [0,1,0]
[0,1,0]
v5 = [0,0,1]
[0,0,1]
v6 = [1,0,1]
[1,0,1]
v7 = [1,1,1]
[1,1,1]
v8 = [0,1,1]
[0,1,1]
append vert_array v1
#([0,0,0])
append vert_array v2
#([0,0,0], [1,0,0])
append vert_array v3
#([0,0,0], [1,0,0], [1,1,0])
append vert_array v4
#([0,0,0], [1,0,0], [1,1,0], [0,1,0])
append vert_array v5
#([0,0,0], [1,0,0], [1,1,0], [0,1,0], [0,0,1])
append vert_array v6
#([0,0,0], [1,0,0], [1,1,0], [0,1,0], [0,0,1], [1,0,1])
append vert_array v7
#([0,0,0], [1,0,0], [1,1,0], [0,1,0], [0,0,1], [1,0,1], [1,1,1])
append vert_array v8
#([0,0,0], [1,0,0], [1,1,0], [0,1,0], [0,0,1], [1,0,1], [1,1,1], [0,1,1])
append face_array [1,4,3]
#([1,4,3])
append face_array [3,2,1]
#([1,4,3], [3,2,1])
append face_array [1,2,6]
#([1,4,3], [3,2,1], [1,2,6])
append face_array [6,5,1]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1])
append face_array [2,3,7]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1], [2,3,7])
append face_array [7,6,2]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1], [2,3,7], [7,6,2])
append face_array [3,4,8]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1], [2,3,7], [7,6,2], [3,4,8])
append face_array [8,7,3]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1], [2,3,7], [7,6,2], [3,4,8], [8,7,3])
append face_array [4,1,5]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1], [2,3,7], [7,6,2], [3,4,8], [8,7,3], [4,1,5])
append face_array [5,8,4]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1], [2,3,7], [7,6,2], [3,4,8], [8,7,3], [4,1,5], [5,8,4])
append face_array [5,6,7]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1], [2,3,7], [7,6,2], [3,4,8], [8,7,3], [4,1,5], [5,8,4], [5,6,7])
append face_array [7,8,5]
#([1,4,3], [3,2,1], [1,2,6], [6,5,1], [2,3,7], [7,6,2], [3,4,8], [8,7,3], [4,1,5], [5,8,4], [5,6,7], [7,8,5])
m = mesh vertices:vert_array faces:face_array
$Editable_Mesh:Object03 @ [0.000000,0.000000,0.000000]
no i niestety efekt nie jest w pełni zadowaljący - na dwóch przeciwległych ściankach pojawiają się krawędzie ścianek, jakby nie były połączone:
jaki błąd popełniłem w skrypcie?
z góry dziękuję
  • Wyświetleń 1,9k
Napisałem to od nowa po swojemu układając vertexy i face'y, gdyż w ten sposób szybciej mogłem wprowadzić dane których u Ciebie brakuje
vert_array = #()
face_array = #()
append vert_array [0,0,0]
append vert_array [0,1,0]
append vert_array [1,0,0]
append vert_array [1,1,0]
append vert_array [0,0,1]
append vert_array [0,1,1]
append vert_array [1,0,1]
append vert_array [1,1,1]
append face_array [2,3,1]
append face_array [3,2,4]
append face_array [5,2,1]
append face_array [2,5,6]
append face_array [6,4,2]
append face_array [4,6,8]
append face_array [8,3,4]
append face_array [3,8,7]
append face_array [7,1,3]
append face_array [1,7,5]
append face_array [7,6,5]
append face_array [6,7,8]
sgroup_array = #(1,1,2,2,4,4,8,8,16,16,32,32)
nowy = mesh vertices:vert_array faces:face_array
for f = 1 to 12 do
setFaceSmoothGroup nowy f sgroup_array[f]
setEdgeVis nowy f 1 false
setEdgeVis nowy f 2 true
setEdgeVis nowy f 3 true
update nowy
Rzeczy, których u Ciebie brakuje, to te, które odbywają się w pętli 'for'
Muszisz jeszcze oprócz tworzenia mesh'a zdefiniować dla każdego face'a smoothing group do jakiej ma należeć:
Do których grup sg należy face, definiuje się za pomocą 32-bitowych (tyle jest grup sg) liczb binarnych. Stąd w tablicy kolejne potęgi dwójki.
Np. liczba 8 (binarnie 1000) oznacza, że face należy do 4 grupy SG
liczba 13 (1101) oznacza, że face należy do grup: 1,3,4
dodatkowo te linie:
pozwalają na ukrycie edge, które są na przekątnych poly.
Wlaśnie dlatego stworzyłem bryłę po swojemu, gdyż u Ciebie pewnie musiałbym inaczej dobierać, które krawędzie ukrywać, a które nie.
Ja się zbytnoi na tym nie znam ale wydaje mi się, że to jest problemem.
Jeśli się mylę, lechoo na pewno mnie skoryguje ;)
***EDIT***
Przejrzałem dokładniej Twój schemat tworzenia bryły i jest tam trzymanie się algorytmu podobnie jak u mnie więc cały ten mój wykład ogranicza się do tego, abyś po linii "m = mesh vertices:vert_array faces:face_array" w swoim skrypcie dodał coś takiego:
for f = 1 to 12 do
setFaceSmoothGroup m f sgroup_array[f]
setEdgeVis m f 1 true
setEdgeVis m f 2 true
setEdgeVis m f 3 false
update m
Teraz nadanie grup SG na box'a jeszcze ujdzie, ale w dalszym zastosowaniu staje się nieco uciążliwe?
Możesz się oddać w ręce automatu. Zamiast tego, co podałem wyżej, wstaw to:
addmodifier m (Smooth autosmooth:true threshold:30)
convertToMesh(m)
update m
parametrem threshold decydujesz, kiedy face'y dostaną te same a kiedy różne grupy SG, po szczegóły już odeślę do help'a bo i tak rozpisałem się tutaj ponad norme ;)
wielkie dzieki :) juz wszystko dziala
i ta druga wersja jest jak narazie dla mnie lepsza - nie ma bledow, bo pierwsza mi tylko czesc siatki wygladzala :)
