Witam!
Mam pewien problem, szukalem na googlu ale nic konkretnego nie znalazlem.
Sprawa wyglada tak. Mam na poniedzialek przygotowac obrazek do wydruku w 100-200 DPI. Problem w tym, ze w Photoshopie (w ktorym robilem obrazek) jest tylko PPI i nie mam pojecia jak sie za bardzo ma rozmiar w PPI do rozmiaru w DPI. Nie chce zeby po wydruku sie poznej okazalo ze obrazek wyszedl 2 razy mniejszy albo w kaszaniastej jakosci bo DPI bylo za male.
Zna sie ktos na tym? Pozmozcie proshe jesli umiecie!
Pozdrawiam!
  • Wyświetleń 2,3k
Contrary to what you might think, ppi is not the same as dpi. Almost everyone these days has a inkjet printer so let's think about your inkjet printer for a moment. How many colors of ink are in your inkjet printer? Most of them have at least four and possibly six ink colors. When your printer lays down ink, it lays it down in overlapping dots of these four or six colors. Images are made up of pixels and Photoshop defines resolution in pixels per inch. In a typical RGB image, a single pixel represents one color out of the millions of colors that can be reproduced on-screen.
So how can a printer with only six colors of ink reproduce millions of colors? Well, certainly not by printing a single dot for each pixel in your image! In reality, for each pixel in an image, your printer may lay down several dots of overlapping color that mix together to make up the color of that single pixel. All this is said to help you understand why you would use an image resolution setting of 150 ppi in Photoshop in order to output an image with a printed resolution of 300 dpi. It's simple; your printer needs to use more than one dot to represent the color of a single pixel.
To clear up another confusing matter, resolution (ppi or dpi) has no bearing at all for images that will be viewed on screen. The only thing that means anything for screen display is the pixel dimensions; that is, the number of pixels that make up the width and the number of pixels that make up the height of the image.
If you've been told that you need to use 72 or 96 ppi for the Web, it's only because that is approximately what a typical monitor can display. But, because we have the ability to adjust the pixel dimensions of our monitor, and because monitors come in varying sizes, an image with the same pixel dimensions is not always going to appear the same size on screen on every system and with every monitor. However, an image that is 100 by 200 pixels will always be 100 x 200 pixels, unless you resample that image. And that brings us right back to the image size dialog box...
http://graphicssoft.about.com/od/photoshop/l/bllps502c.htm
Definition: Resolution is a measurement of the output quality of an image, usually in terms of samples, pixels, dots, or lines per inch. The terminology varies according to the intended output device. PPI (pixels per inch) refers to screen resolution, DPI (dots per inch) refers to print resolution, SPI (samples per inch) refers to scanning resolution, and LPI (lines per inch) refers to halftone resolution.
http://graphicssoft.about.com/od/glossary/g/resolution.htm
dpi, ppi, lpi
Bardzo powszechnie mówi się o rozdzielczości jako ilości pikseli na jednostkę długości. Tą jednostką długości jest cal (2.54 cm). Producenci urządzeń (szczególnie: drukarki, skanery, plotery) w dokumentacjach podają rozdzielczość pracy urządzenia jako liczbę XXX dpi. Ta wartość XXX to właśnie ilość drukowanych lub rozróżnianych punktów na odcinku 1 cala. Termin "dpi" to skrót zwrotu angielskiego: "dots per inch" (kropek na cal). Skrót: dpi jako ilość kropek na cal bardziej odpowiada dla urządzeń drukujących. Obok skrótu dpi jest używany skrót: ppi, z angielskiego: "point per inch" albo "pixel per inch". Skrót ppi jest bardziej odpowiedni dla urządzeń typu skaner, to znaczy urządzeń rejestrujących. Praktycznie używa się obydwu skrótów mimo, że można spotkać odmienne zdania na ten temat. Skrót dpi jest bardziej popularny i częściej używany.
Zarówno dpi jak i również ppi jest trochę nieokreśloną miarą, bowiem ta miara nic nie mówi o proporcji punktu. Można jedynie zakładać, że rozdzielczość przez nią określona dotyczy w domniemany sposób punktów kwadratowych. W zastosowaniach praktycznych, występuje jeszcze jedna miara: lpi z angielskiego: "lines per inch" (linii na cal). Ta miara mówi nam o rozdzielczości drugiego wymiaru. Najczęściej mamy sytuację, że dpi lub ppi określa rozdzielczość poziomo a lpi określa rozdzielczość pionowo.
http://semmix.pl/color/elempic/ep20.htm
Czyli na moj prosty łeb, to jest to samo i przelicznik jest 1:1, z ta roznica ze jedno odnosi sie do drukarki a drugie do monitora.
