Jest już dostępny drugi Hotfix dla May'i:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17137651&linkID=9242259
General updates
Mental ray Satellite update
Maya 2012 now includes four mental ray Satellite network rendering licenses, which allows you to freely use up to four slave machines (with up to four processors each and an unlimited number of cores) for mental ray network rendering.
Naprawione błędy:
374184
Goal issue when using a straight curve
380975
Load render pass doesn't work when project is on network share
381943
Shadow artifacts occurs with large differences in object size
382170
Connecting luminance node to bump channel of mental ray shader causescrash
382221
UNC path bookmarks are not saved in new filebrowser
382758
Final gather map visualization not working
384017
Painting blendshapes problems
384043
Wacom tablet not working correctly in mouse mode
384291
dagContainer collapses at every DAGoperation
384302
Unpredictable results referencing HIK characters
384314
Creating Framebuffer with a Geometry shader causes a crash
384392
Joint orient channels not accepting setAttr correctly
384523
Graph editor:cannotview multiple f‐curves on a character set
385368
Polysplit crash
385417
Metacarpal fingers not created when creating HIK control rig
385873
Pinning an effector is causing the pivot display to jump
380473
Missing manipulator handles in perspective view
375080
Adaptivesampling gives lower shading quality in framebuffers
380236
mia_material_x preset 'Satined Metal' renders differently
380322
Scenes with dense final gather settings may have longer render time
380847
Render with mental ray errors with multi‐shape polygons
382154
HIK: Shift+LMBdoes not allow for selection of keys on timeline if HIK in scene
383833
New option in move tool broken
  • Wyświetleń 3k
