PySide - SpinningWheelWidget
Jakiś czas temu szukałem widgeta od "buforowania" (ten kręcący się wiatraczek), nie znalazłem i użyłem gifa. Mam trochę czasu w domu to napisałem taki widgecik. Może komuś się przyda :)
from PySide.QtGui import QWidget
from PySide.QtGui import QPainter
from PySide.QtGui import QColor
from PySide.QtCore import QTimer, Qt, QRect
from PySide.QtCore import Slot
import time
class SpinningWheelWidget(QWidget):
   def __init__(self,
                parent=None,
                spin_steps=12,
                bar_roundness=1.0,
                ticker_color=QColor(255, 255, 255),
                fade_to_color=QColor(32, 32, 32)):
       QWidget.__init__(self, parent)
       self.spin_steps = max(8, spin_steps)
       self.bar_width = .1
       self.bar_height = .5
       self.bar_roundness = max(0.0, min(1.0, bar_roundness))
       self._fps = 24
       self._current_step = 0
       self._last_tick = time.time()
       self._step_interval = 1.0 / self.spin_steps
       self._update_timer = QTimer()
       self._update_timer.setInterval(1000 / self._fps)
       # noinspection PyUnresolvedReferences
       self._update_timer.timeout.connect(self.fade_colors)
       # --- Colors setup
       self.r_from = ticker_color.red()
       self.g_from = ticker_color.green()
       self.b_from = ticker_color.blue()
       self.r_to = fade_to_color.red()
       self.g_to = fade_to_color.green()
       self.b_to = fade_to_color.blue()
       self._lerps = list()
       for i in range(self.spin_steps):
           lerp_value = float(i) / (self.spin_steps - 1)
           self._lerps.append(lerp_value)
       self._lerps[0] = 1.0
       self._spin_angle = 360 / self.spin_steps
       self.setMinimumSize(16, 16)
   def showEvent(self, event):
       self._update_timer.start()
   def hideEvent(self, event):
       self._update_timer.stop()
   def set_ticker_color(self, ticker_color):
   def set_fade_to_color(self, fade_to_color):
       self.r_from = fade_to_color.red()
       self.g_from = fade_to_color.green()
       self.b_from = fade_to_color.blue()
   @Slot()
   def fade_colors(self):
       for i in range(len(self._lerps)):
           self._lerps[i] -= self._fps / 1000.0
       tick = time.time()
       delta_t = tick - self._last_tick
       if delta_t >= self._step_interval:
           self._current_step += 1
           if self._current_step >= self.spin_steps:
           self._lerps[self._current_step] = 1.0
           self._last_tick = tick
       self.update()
   def paintEvent(self, event):
       painter = QPainter(self)
       painter.setRenderHints(painter.Antialiasing)
       rect = self.geometry()
       short_side = min(rect.width(), rect.height())
       if short_side             return
       painter.setPen(Qt.NoPen)
       painter.translate(rect.width() / 2, rect.height() / 2)
       bar_width = short_side * self.bar_width
       round_radius = (bar_width / 2) * self.bar_roundness
           painter.setBrush(self._get_interpolated_color(self._lerps[i]))
           paint_rect = QRect(-bar_width / 2,
                              -short_side / 2,
                              bar_width,
                              (short_side * self.bar_height) / 2)
           if round_radius > 0:
               painter.drawRoundedRect(paint_rect,
                                       round_radius,
                                       round_radius)
           else:
               painter.drawRect(paint_rect)
           painter.rotate(self._spin_angle)
   def _get_interpolated_color(self, i):
       interp = min(1.0, max(0.0, i))
       return QColor(int(((self.r_from - self.r_to) * interp) + self.r_to),
                     int(((self.g_from - self.g_to) * interp) + self.g_to),
                     int(((self.b_from - self.b_to) * interp) + self.b_to))
  • Wyświetleń 2,5k
