3dsmax 2012 vray renderuje na pół gwizdka
Hello! Retro pytanie.
Max 2012 (dwanaście) renderuje na pół mocy procesora. Tylko połowa bucketow. Był chyba jakiś skrypt do tego ale nie mogę odnaleźć. Pamięta ktoś?
  • Odpowiedzi 1
  • Wyświetleń 647
  • Znalazłem! 😉     https://forums.cgsociety.org/t/help-vray-not-using-cpus/1453655/3
Znalazłem! 😉
Cytat
here’s a trick for setting the cores v-ray/MAX uses when rendering:
open max, press F11. a white and pink box pops up.
copy this into the white space and press enter:
renderers.current.system_numThreads=4
this will set your CPU threads to use 4 cores on your current computer.
just change the “4” in the above line of code to any value you want, and max will render with that many threads.
if you are on a dualCore and you set the threads to 4, each processor will be rendering 2 buckets, so try to set the # to the # of cores you have.
Hope this helps.
