Pytanie:
Jaki skrót klawiszowy słóży do obrócenia zaznaczonych poly.
Opis:
Mam element zaznaczam kilka poly, jakim skrótem klawiszowym odznaczam wszystkie zaznacozne polygony a zaznaczam pozostale taka zamiana jak gdyby. Dzieki
Moze ktos wie gdzie mozna znalesc wszystkie skróty klawiszowe maxa i kombinacje, Zeby mozna bylo sobie wydrukowac w kolumnie na kartce.
Pytanie 2:
Gdzie moge powiekszyc rozmiar OSI (X,Y,Z) tych strzaleczek zeby bylo latwiej trafic wnie:]
  • Wyświetleń 1,5k
pytanie 2:
używaj helpa Maxa - ja wyszukałem "gizmo", potem wybrałem preferences i już mam! oto opis z helpa:
Gizmo Preferences
Customize menu > Preferences > Preference Settings dialog > Gizmos tab
The Gizmos Preferences Settings dialog lets you set the display and behavior of the Transform gizmos.
Interface
Transform Gizmos group
On—When on, 3ds max uses the Transform gizmo to enable more powerful move, rotate, and scale options. When turned off, a basic tripod is displayed, with no axis specificity.
Show Axis Labels—Toggles the display of the axis labels on the Transform gizmo.
Note: Functionality is maintained when axis labels are turned off.
Allow Multiple Gizmos—Toggles the display of more than one gizmo at a time.
When turned off, a Transform gizmo will only be displayed for one object at a time in a selection set.
When turned on and when Use Pivot Point Center in the Use Center flyout is active, each object in a selection set will have its own transform gizmo.
Size—Sets the size of the Transform gizmo as a percentage of the viewport size. Range=1 to 100.
Move Gizmo group
Relative Size (%)—Sets the size of the Move gizmo, relative to the Size value of the Transform gizmo. Range= 0.0 to 500.0.
Plane Handles group
The plane handles let you constrain object movement along combinations of any two axes.
On—Toggles the use of plane handles on the Transform gizmo.
Size—Sets the size of the plane handles, as a percent of the distance from the Offset to the tripod axis. Range=0.0 to 100.0.
****EDIT****
powód? źle kliknąłem i się zrobił spam na forum :)
co do skrótów klawiaturowych to SansSerif dawał kiedyś linki do maxa, photoshopa i jeszcze tam czegoś, poszukaj na forum.
pyt1. Select -> Select Invert Ctr+I
pyt2. "+" i "-" na klawiaturze
OKi wielkie dzieki.
Pytanie nr.3:
Szukalem w opcjach klawiszowych ale nie moglem znalesc chodzi mi o skrot do funkcji
RING - w editablepoly
Loop
oraz Glow
Dziekuje i Zycze WesołychSwiat!
streaker- juz troszke szukalem tego na forum ale nie moge znalesc tego linka co podawal.
Mozesz zazucic nim tutaj na forum, bardzo bym Cie prosil.
Pozdrawiam All
Domel stwórz swój skrót jak nie ma ... ja tak oczywiście zrobiłem "right" view , i "back "oraz "move" i "pepsi" ...... w ogole przykróciłem to co mnie wkurzało że nie ma.
