Mam box'a :-) Chce by mozna go bylo przesuwac w viewport'cie maksymalnie np. o 10 jednostek w kazdej osi.
when transform $box01 changes do (
if $box01.pos.X>10 then $box01.pos.X=10
Taka postac skryptu dziala, ale tylko wzgledem osi X (oczywscie ogranicza ruch tylko w prawo). Gdy dopisuje:
if $box01.pos.Y>10 then $box01.pos.Y=10
i alternatywnie dla Z to nie dziala. O co chodzi?
  • Wyświetleń 1,8k
Napisałeś tak:
if $box01.pos.Y>10 then $box01.pos.X=Y
Nie powinno być:
if $box01.posY>10 then $box.posY=10
posY -taka skladnia nie wystepuje
Faktycznie dziwne. Rzucilem to pytanie na forum cgtalku, zobaczymy co tam wymysla.
Dostalem taka odpowiedz:
This might not be exactly an error, but it is a limitation. I *assume* it is caused by the way interactive manipulations are applied to the controller hierarchy and the notifications sent to the system and MAXScript.
A workaround I found is to assign a Bezier Position controller to the Position track - when there are no sub-controllers, all 3 axes are being processed correctly.
Another workaround is to use the handerAt:#redrawViews option. The object does not stop when the Y reaches the limit, but as soon as the view is redrawn, the object jumps back to the limit.
And of course the Limit controller in Max 8 would be the clean solution to the problem.
