Na poczatek moja wersja skryptu. W tym temacie chodzilo glownie o zapoznanie sie z interfejsem ale przy okazji wyniklo kilka innych ciekawych problemow.
utility teapot_util \"Teapot\"
local my_teapot
button create_teapot \"Create teapot\"
colorpicker teapot_color \"Teapot Color: \" color:[100,100,255] fieldwidth:50 title:\"Pick Teapot color\" align:#right enabled:false
spinner teapot_radius \"Teapot size: \" type:#float range:[0,200,30] fieldwidth:40 enabled:false align:#right
slider teapot_segments \"Segments\" type:#integer range:[1,20,5] enabled:false
group \"Teapot Parts\"
checkbox teapot_body \"Body\" checked:true across:2 enabled:false
checkbox teapot_handle \"Handle\" checked:true across:1 enabled:false
checkbox teapot_spout \"Spout\" checked:true across:2 enabled:false
checkbox teapot_lid \"Lid\" checked:false across:1 enabled:false
button delete_teapot \"Delete Teapot\"
on create_teapot pressed do
my_teapot = teapot()
my_teapot.wirecolor = teapot_color.color
my_teapot.radius = teapot_radius.value
my_teapot.segments = teapot_segments.value
my_teapot.body = teapot_body.checked
my_teapot.handle = teapot_handle.checked
my_teapot.spout = teapot_spout.checked
my_teapot.lid = teapot_lid.checked
teapot_color.enabled = true
teapot_radius.enabled = true
teapot_segments.enabled = true
teapot_body.enabled = true
teapot_handle.enabled = true
teapot_spout.enabled = true
teapot_lid.enabled = true
on teapot_color changed val do my_teapot.wirecolor = val
on teapot_radius changed val do my_teapot.radius = val
on teapot_segments changed val do my_teapot.segments = val
on teapot_body changed val do my_teapot.body = val
on teapot_handle changed val do my_teapot.handle = val
on teapot_spout changed val do my_teapot.spout = val
on teapot_lid changed val do my_teapot.lid = val
on delete_teapot pressed do
teapot_color.enabled = false
teapot_radius.enabled = false
teapot_segments.enabled = false
teapot_body.enabled = false
teapot_handle.enabled = false
teapot_spout.enabled = false
teapot_lid.enabled = false
delete my_teapot
Co nowego? Przedewszystkim elementy interfejsu. Moze krotkie omowienie na przykladzie spinnera.
spinner - typ kontrolki (moze tez byc button, slider, checkbox itd)
teapot_radius - nazwa kontrolki przez ktora bedziemy sie potem do niej odwolywac. Odradzam uzywanie tu nazw typu spiner1 czy spiner2, kiedy jest ich kilkabardzo latwo wszystko pokrecic.
\"Teapot size: \" - tekst ktory pojawi sie przy spinerze w menu
type:#float - rodzaj liczb ktore beda wyswietlane w spinerze. Tutaj liczby rzeczywiste (pozatym sa tez #integer czyli liczby calkowite i #worldunits czyli maxowe unity)
range:[0,200,30] - zakres liczb wyswietalnych w okienku spinera [min,max,wartosc_domyslna]
fieldwidth:40 - szerokosc pola spinera
enabled:false - ta wlasciwosc okresla czy element bedzie wlaczony
align:#right - i na koniec wyrownanie do lewej
Jak pewnie zauwarzyliscie czesc parametrow, jak np. enabled czy align jest wspolna dla wszystkich elementow interfejsu. Z przydatniejszych warto wspomniec tez o offset ktory ustawia dokladnie konkretny element. Jesli nasz button jest za wysoko wystarczy dodac offset:[0,-10] aby przesunac go o 10 pikseli w dol. Innym przydatnym parametrem jest across ktory umozliwia ustawianie elementow obok siebie.
button guzik1 \"Opcja 1\"
button guzik2 \"Opcja 2\"
button guzik3 \"Opcja 3\"
Tak zdefiniowane przyciski beda umieszczone jeden pod drugim. Drobna modyfikacja pozwala umiescic je obok siebie.
button guzik1 \"Opcja 1\" across:3
button guzik2 \"Opcja 2\" across:2
button guzik3 \"Opcja 3\" across:1
  • Odpowiedzi 15
  • Wyświetleń 3,4k
Autor: Bart
Utility czajnik \"Czajnik\"
local pot
label l1 \"\"
button tea \"Create Teapot\"
label l2 \"\"
colorpicker Pik \"Wire color:\" color:[0,0,255] enabled:false
label l3 \"\"
group \"Teapot parts\"
checkbox Body \"Body\" checked:true enabled:false
checkbox Handle \"Handle\" checked:true enabled:false
checkbox Spout \"Spout\" checked:true enabled:false
checkbox Lid \"Lid\" checked:true enabled:false
group \"Parameters\"
spinner Rad \"Radius \" range:[10,100,40]align:#left enabled:false
slider Seg \"Segments \" range:[4,20,6] type:#integer enabled:false
button del_pot \"Delete Teapot\" enabled:false
on Pik changed kolor do
pot.wirecolor = kolor
on Body changed arg do
pot.body=arg
on Handle changed arg do
pot.handle=arg
on Spout changed arg do
pot.spout=arg
on Lid changed arg do
pot.lid=arg
on tea pressed do
pot=teapot radius:40 segments:6
pot.wirecolor=[0,0,255]
tea.enabled=false
pik.enabled=true
Body.enabled=true
Handle.enabled=true
Spout.enabled=true
Lid.enabled=true
Rad.enabled=true
Seg.enabled=true
del_pot.enabled=true
on del_pot pressed do
select pot
delete selection
Body.checked=true -- ponowne zaznaczenie wszystkich checkboxow
Handle.checked=true
Spout.checked=true
Lid.checked=true
Pik.color=[0,0,255] -- ustawienie colorpikera na defoultowy
Rad.value=40 -- ustawienie spinnera i slidera na wart. defoultowe
Seg.value=6
tea.enabled=true
pik.enabled=false
Body.enabled=false
Handle.enabled=false
Spout.enabled=false
Lid.enabled=false
Rad.enabled=false
Seg.enabled=false
del_pot.enabled=false
on seg changed value do
pot.segs=Seg.value
on rad changed value do
pot.radius=Rad.value
)--End utility
W temacie chcialem zebyscie zmieniali parametry czajniczka w momencie zmieniania ustawien w interfejsie. Dla wiekszosci elementow interfejsu robi sie to w ten sam sposob.
on nazwa_elementu changed nowa_wartosc do
--jakis kod np.
jakis_parametr = nowa_wartosc
Zasada dzialania jest bardzo prosta. W monencie zmiany ustawienia, wartosci kontrolki wykonywany jest kod pomiedzy nawiasami a wlasnie wprowadzona wartosc jest umieszczana w zmiennej nowa_wartosc. Jesli naszym elementem jest spiner bedzie tam liczba, jesli colorpicker bedzie to kolor a jesli checkbox nowa_wartosc bedzie mogla byc true lub false. W przypadku buttona nic nie jest przekazywane, wykonywany jest jedynie kod.
Jedyne do czego moglbym sie \"przyczepic\" w tym skrypcie to sposob okreslenie parametrow czajniczka w momencie jego tworzenia. Eleganciej byloby zamiast
pisac
pot.wirecolor = Pik.color
czyli od razu inicjalizowac wartoscia a interfejsu.
Autor: Bartłomiej Cysewski
utility Bart \"Temat 2\"
--definicja elementów interfejsu
button b1 \"Stwórz\"
colorpicker b2 \"Kolor siatki\"
spinner b3 \"Rozmiar\" range:[1,100,25] type:#integer
slider b4 \"Szczegółowość siatki\" range:[3,20,4]
checkbox c1 \"Dziobek\"
checkbox c2 \"Pokrywka\"
checkbox c3 \"Uchwyt\"
checkbox c4 \"Korpus\"
button b5 \"Usuń\"
--tworzenie teapot\'a
on b1 pressed do
tea = teapot()
--zmiana koloru siatki
on b2 changed col do
tea.wirecolor = col
--zmiana rozmiaru teapot\'a
on b3 changed rad do
tea.radius = rad
--zmiana gęstości siatki
on b4 changed seg do
tea.segs = seg
--ukrycie dzióbka
on c1 changed a1 do
tea.spout = not tea.spout
--ukrycie pokrywki
on c2 changed a2 do
tea.lid = not tea.lid
--ukrycie uchwytu
on c3 changed a3 do
tea.handle = not tea.handle
--ukrycie korpusu
on c4 changed a4 do
tea.body = not tea.body
--usunięcie teapot\'a
on b5 pressed do
delete $teapot01
) --koniec utility
Tutaj pojawia sie problem ktory mialem z chyba polowa skryptow. Jesli spojrzycie na poprzedni skrypt zauwarzycie deklaracje w trzeciej linijce
local pot
Dzieki temu zmienna pot jest widoczna w calym skrypcie, natomiast tutaj zmienna tea czyli ta w ktorej przechowywany jest teapot jest widoczna tylko w zdarzeniu
on b1 pressed do
Efekt jest taki ze w momencie kiedy proboje zmienic jakis parametr script sie wywala bo w zdarzeniu np.
on c3 changed a3 do
nie ma deklaracji tej zmiennej i nie jest ona tu znana.
Podejrzewam ze czesc z Was mogla pisac w maxie 3 gdzie wszystkie zmienne byly deklarowane domyslnie jako globalne i wtedy nie ma takiego problemu. Natomiast w maxie 4 i 5 zmienne domyslnie ustawiane sa na lokalne. Kiedy przesiadlem sie na maxa 4 nie wiedzialem o tym i mialem spore problemy bo nic mi nagle nie dzialalo.
Musze jeszcze wspomniec o kasowaniu teapota
on b5 pressed do
delete $teapot01
Jak widac odwolanie do obiektu nastepuje przez jego nazwe, moze to rodzic problemy jesli w scenie juz byl inny czajnik o takiej samej nazwie.
Autor: BooM-Bel
utility bmb \"BooM-Bel\"
button tp \"czajniczek\" -- tworzenie czajniczka
colorpicker wctp \"kolor\" color:[125,125,125] enabled:false-- określenie koloru siatki
spinner rtp \"romiar\" range:[1,50,10] type:#integer enabled:false-- wielkość czajniczka
slider stp \"siatka\" range:[1,12,6] type:#integer enabled:false-- szczegółowość siatki
Group \"ukryj czesci dzbanka\" -- ukrywanie elementów
checkbox cb1 \"przykrywka\" enabled:false checked:true-- przykrywka
checkbox cb2 \"dziubek\" enabled:false checked:true-- dziubek
checkbox cb3 \"uszko\" enabled:false checked:true-- uszko
checkbox cb4 \"dzbanuszek\" enabled:false checked:true-- cały dzbanuszek
button ktp \"kasuj\" enabled:false-- kasowanie czajniczka
on tp pressed do --tworzenie dzbanka i udostępnianie pozostałych funkcjii
tpo = teapot radius:rtp.value
tpo.name = \"dzbanuszek\"
tpo.wirecolor = wctp.color
tpo.segs = stp.value
wctp.enabled=true
rtp.enabled=true
stp.enabled=true
cb1.enabled=true
cb2.enabled=true
cb3.enabled=true
cb4.enabled=true
ktp.enabled=true
on wctp changed new_col do -- określenie koloru siatki
on rtp changed value do-- wielkość czajniczka
tpo.radius=value
on stp changed value do-- szczegółowość siatki
tpo.segs=value
on cb1 changed false do-- ukrywanie przykrywka
tpo.lid=false
on cb1 changed true do-- pokazywanie przykrywka
tpo.lid=true
on cb2 changed false do-- ukrywanie dziubek
tpo.spout=false
on cb2 changed true do-- pokazywanie dziubek
tpo.spout=true
on cb3 changed false do-- ukrywanie uszka-
tpo.handle=false
on cb3 changed true do-- pokazywanie uszka
tpo.handle=true
on cb4 changed false do-- ukrywanie dzbanka
tpo.body=false
on cb4 changed true do-- pokazywanie dzbanka
tpo.body=true
on ktp pressed do --kasowanie dzbanka i ukrywanie pozostałych funkcjii
delete tpo
wctp.enabled=false
rtp.enabled=false
stp.enabled=false
cb1.enabled=false
cb2.enabled=false
cb3.enabled=false
cb4.enabled=false
ktp.enabled=false
Jedyny problem to brak deklaracji zmiennej o ktorej pisalem post wczesniej. Dajcie znac ktorej wersji maxa uzywacie, ja mam 5.0 i u mnie bez tej deklaracji niestety nie chodzilo.
Autor: leander
utility czajnik \"Czajnik Manager v1.0\"
button stworz \"Stwórz\" align:#left across:2 tooltip:\"Stwórz czajnik\"
button skasuj \"Skasuj\" align:#right enabled:false tooltip:\"Skasuj czajnik\"
spinner rozmiar \"Rozmiar:\" range:[0,100,25] type:#float enabled:false
slider siatka \"Szczegolowosc siatki:\" range:[0,15,5] type:#integer enabled:false ticks:15
checkbox pokrywka \"Pokrywka\" enabled:false checked:true
checkbox dziobek \"Dzióbek\" enabled:false checked:true
checkbox uchwyt \"Uchwyt\" enabled:false checked:true
checkbox korpus \"Korpus\" enabled:false checked:true
on stworz pressed do
myCZAJNIK = teapot()
skasuj.enabled = true
rozmiar.enabled = true
siatka.enabled = true
pokrywka.enabled = true
dziobek.enabled = true
uchwyt.enabled = true
korpus.enabled = true
on rozmiar changed val do myCZAJNIK.radius = val
on siatka changed val do myCZAJNIK.segs = val
on pokrywka changed STATUS do
if STATUS == false then
myCZAJNIK.lid = false
else
myCZAJNIK.lid = true
on dziobek changed STATUS do
myCZAJNIK.spout = false
else
myCZAJNIK.spout = true
on uchwyt changed STATUS do
myCZAJNIK.handle = false
else
myCZAJNIK.handle = true
on korpus changed STATUS do
myCZAJNIK.body = false
else
myCZAJNIK.body = true
on skasuj pressed do
delete(myCZAJNIK)
-- \"zerowanie\" zmniennych:
skasuj.enabled = false
rozmiar.enabled = false
siatka.enabled = false
rozmiar.value = 25
siatka.value = 5
pokrywka.enabled = false
dziobek.enabled = false
uchwyt.enabled = false
korpus.enabled = false
pokrywka.state = true
dziobek.state = true
uchwyt.state = true
korpus.state = true
Poza brakiem deklaracji zmiennej przechowujacej tepot wszystko OK.
Zwrocilem uwage na sposob ustawiania widocznosci poszczegolnych elementow czjniczka.
else
Mozna duzo prosciej, przeciez w zmiennej STATUS jest juz potrzebna Ci wartosc.
on korpus changed STATUS do CZAJNIK.body = STATUS
Autor: Sypo
utility skrypt \"Zadanko\"
local pot
rollout cre \"Create\"
group \"Temat 2\"
button tea \"Teapot\" width:45 height:20
button closet \"Close Teapot\" enabled:false offset:[1,5]
spinner rad \"Radius: \" range:[1,50,20] width:80 height:25 enabled:false offset:[23,25] type:#float
slider seg \"Segments: \" range:[4,32,12] enabled:false type:#integer
colorpicker kol \"Kolor: \" color:[77,110,141] width:80 height:20 enabled:false offset:[13,5]
group \"Fragmenty\"
checkbox bod \"Body\" checked:true enabled:false
checkbox han \"Handle\" checked:true enabled:false
checkbox spo \"Spout\" checked:true enabled:false
checkbox lid \"Lid\" checked:true enabled:false
on tea pressed do
pot = Teapot radius:20
pot.segs = seg.value
pot.wirecolor = kol.color
pot.name = \"Czaj\"
closet.enabled = not closet.enabled
rad.enabled = not rad.enabled
seg.enabled = not seg.enabled
kol.enabled = not kol.enabled
bod.enabled = not bod.enabled
han.enabled = not han.enabled
spo.enabled = not spo.enabled
lid.enabled = not lid.enabled
on closet pressed do
delete pot
rad.value = 20
bod.checked = on
han.checked = on
spo.checked = on
lid.checked = on
pot.radius=rad.value
on kol changed new_col do
on bod changed new_checked do
pot.body = bod.checked
on han changed new_checked do
pot.handle = han.checked
on spo changed new_checked do
pot.spout = spo.checked
on lid changed new_checked do
pot.lid = lid.checked
on skrypt open do
addRollout cre
on skrypt close do
removeRollout cre
Wszystko w najlepszym porzadku. Zwroccie uwage na tworzenie wlasnego rolloutu i zdarzenia
on skrypt open do
on skrypt close do
ktore pozwalaja przygotowac sobie jakies dane i posprzatac po sobie gdy skrypt jest zamykany.
Autor: VGTsXVII
utility opcje \"VGTsXVII_Teapot\"
global obiekt
button przycisk01 \"Create\"
colorpicker kolor \"Wire color:\" color:[255,255,255] align:#center enabled:false
on kolor changed new_col do selection.wirecolor = new_col
spinner wielkosc \"Wielkosc:\" range:[0,100,10] align:#center fieldwidth:25 type:#integer enabled:false
on wielkosc changed val do selection.radius = val
slider gestosc \"podzial:\" range:[1,32,4] ticks:16 align:#center enabled:false
on gestosc changed val do obiekt.segs = val
checkbox box1 \"pokrywka\" offset:[20,0] enabled:false checked:true
on box1 changed val do obiekt.lid=val
checkbox box2 \"dziobek\" offset:[20,0] enabled:false checked:true
on box2 changed val do obiekt.spout=val
checkbox box3 \"uchwyt\" offset:[20,0] enabled:false checked:true
on box3 changed val do obiekt.handle=val
checkbox box4 \"korpus\" offset:[20,0] enabled:false checked:true
on box4 changed val do obiekt.body=val
button przycisk02 \"Delete\" enabled:false
on przycisk01 pressed do
obiekt=teapot()
obiekt.wirecolor=[255,255,255]
obiekt.radius=10
obiekt.segs=4
select(obiekt)
kolor.enabled=true
wielkosc.enabled=true
gestosc.enabled=true
box1.enabled=true
box2.enabled=true
box3.enabled=true
box4.enabled=true
przycisk02.enabled=true
on przycisk02 pressed do
delete(obiekt)
kolor.color=[255,255,255]
kolor.enabled=false
wielkosc.value=10
wielkosc.enabled=false
gestosc.value=4
gestosc.enabled=false
box1.checked=true
box1.enabled=false
box2.checked=true
box2.enabled=false
box3.checked=true
box3.enabled=false
box4.checked=true
box4.enabled=false
przycisk02.enabled=false
Wszystko w porzadku. Tym razem obiekt zostal zadeklarowany jako globalny. Roznica polega na tym ze wtedy jest widziany tez przez inne skrypty, co pozwalaloby np. wymieniac im dane. Az sie prosi o jakies zadanie na ten temat :D
Autor: Warui
utility czajnik_uti \"Czajnik (Kurs MAX Script 2)\"
button utwoz \"Utworz Czajnik\" enabled:true
group \"Parametry\"
colorpicker kolor \"Kolor:\" color:(random black white)
enabled:false align:#center width:90
spinner rozmiar \"Rozmiar:\" range:[0,100,20] type:#worldunits
fieldwidth:40 enabled:false align:#center
slider segmenty \"Segmantacja:\" range:[0,15,4] type:#integer
label lab1 \"Pokaz:\" align:#left enabled:false
checkbox pokrywka \"Pokrywka\" checked:true across:2 enabled:false
checkbox ucho \"Ucho\" checked:true offset:[10,0] enabled:false
checkbox dziobek \"Dziobek\" checked:true across:2 enabled:false
checkbox korpus \"Korpus\" checked:true offset:[10,0] enabled:false
button skasuj \"Skasuj Czajnik\" enabled:false
group \"O skrypcie\"
label lab2 \"\"Czajnik\" by Warui\"
label lab3 \"© 2003\"
rollout ustawienia \"Ustawienia\"
label lab4 \"Pozycja czajnika:\" align:#left
spinner x \"x:\" range:[-1000,1000,0] type:#worldunits
fieldwidth:40 align:#left across:3
spinner y \"y:\" range:[-1000,1000,0] type:#worldunits
fieldwidth:40 align:#center
spinner z \"z:\" range:[-1000,1000,0] type:#worldunits
fieldwidth:40 align:#right
button ok \"OK\" width:100
on ok pressed do
czajnik = teapot radius:20 segs:4
wirecolor:kolor.color pos:[x.value,y.value,z.value]
destroydialog ustawienia;
function zmien_dostepnosc =
utwoz.enabled = not utwoz.enabled
skasuj.enabled = not skasuj.enabled
kolor.enabled = not kolor.enabled
rozmiar.enabled = not rozmiar.enabled
segmenty.enabled = not segmenty.enabled
lab1.enabled = not lab1.enabled
pokrywka.enabled = not pokrywka.enabled
ucho.enabled = not ucho.enabled
dziobek.enabled = not dziobek.enabled
korpus.enabled = not korpus.enabled
on utwoz pressed do
zmien_dostepnosc()
createdialog ustawienia modal:true width:250
zmien_dostepnosc()
if(isvalidnode czajnik) then delete czajnik
-- resetujemy do ustawien poczatkowych
kolor.color = (random black white)
rozmiar.value = 20
segmenty.value = 4
pokrywka.checked = true
ucho.checked = true
dziobek.checked = true
korpus.checked = true
on kolor changed nowy_kolor do czajnik.wirecolor = nowy_kolor
on rozmiar changed nowy_rozmiar do czajnik.radius = nowy_rozmiar
on segmenty changed nowa_segmentacja do czajnik.segs = nowa_segmentacja
on pokrywka changed zmiana_pokrywki do czajnik.lid = zmiana_pokrywki
on ucho changed zmiana_ucha do czajnik.handle = zmiana_ucha
on dziobek changed zmiana_dziobka do czajnik.spout = zmiana_dziobka
on korpus changed zmiana_korpusu do czajnik.body = zmiana_korpusu
Chyba najciekawszy skrypt. Brak deklaracji zmiennej ale zwroccie uwage na dwie rzeczy:
- funkcje createdialog ktora powoduje wyswietlenie wczesniej zdefiniowanego rolloutu jako osobnego okienka
- sposob kasowania czajniczka
Wlasciwie zawsze powinno sie tak robic. Funkcja IsValidNode sprawdza czy rzeczywiscie czajnik istnieje i dopiero wtedy mozliwe jest jego skasowanie. Bez tego zabezpieczenia skrypt wysypalby sie gdybym skasowal teapota klawiszem Del a potem probowal zrobic to jeszcze raz skryptem.
I drugi temat za nami :)
Temat wydaje mi sie dosc prosty choc czesc osob twierdzila przeciwnie, moze to wyjasnia slabsza frekwencje. Musze dobrze przemyslec nastepny , tak zeby byl lepiej wywazony. Do piatku wrzuce go na forum.
Swoja droga ciekawe czy ustanowilem jakis rekord w dlugosci pojedynczego posta :)
Rekordy długości to dopiero będą jak pojawią się jeszcze bardziej złożone zadanka. :D
Frekwencja nieco podupadła, ale oby wyjątkowo, bo ponownie od samych uczestników wychodzą nowe i całkiem ciekawe rzeczy.
W połączeniu z opisem ich działania daje to bardzo dobrze przyswajalną wiedzę.
Oj aż mi się gęba ucieszyła jak zobaczyłem skrypt Warui :) W momencie kasowania teapot\'a na klawiaturze cały skrypt mi wariował a tu taka niespodzianka!! A ja już zacząłem z tego wszystkiego o callbackach czytać:)
Jak gadalismy na gg, to prosiłem Cię zebyś to dopisał ;)
Faktycznie. Moj blad :(
Nastepnym razem postaram sie oceniac skrypty na bierzaco jak przychodza (oczywiscie u siebie lokalnie, nie na forum), a nie wszystko na koniec, wtedy nie bedzie takich wpadek.
