Maya nie uruchamia się.
Najpierw wyskakuje błąd:
potem otwiera się monsola a w niej...
// Error:  //
// Error: Syntax error //
// Error: Fur::executeCommand MayaState: (kFailure): Unexpected Internal Failure //
// Error: initializePlugin function failed (Fur) //
// mental ray for Maya 9.0
// mental ray for Maya: using startup file /autodesk/maya2008/mentalray/maya.rayrc
// mental ray for Maya: setup
// mental ray for Maya: initialize
// mental ray for Maya: using 1 license
// mental ray for Maya: register extensions
// mental ray Node Factory: loaded
// mental ray for Maya: successfully registered
// mental ray for Maya: loading startup file: /autodesk/maya2008/mentalray/maya.rayrc
// parsing /autodesk/maya2008/mentalray/include/BA_color_clamprange.mi
// loading /autodesk/maya2008/mentalray/lib/BA_color_clamprange.so
// generating Maya nodes...
// parsing /autodesk/maya2008/mentalray/include/BA_color_mixer.mi
// loading /autodesk/maya2008/mentalray/lib/BA_color_mixer.so
// parsing /autodesk/maya2008/mentalray/include/BA_color_raylength.mi
// loading /autodesk/maya2008/mentalray/lib/BA_color_raylength.so
// parsing /autodesk/maya2008/mentalray/include/BA_color_rgba_combine.mi
// loading /autodesk/maya2008/mentalray/lib/BA_color_rgba_combine.so
// parsing /autodesk/maya2008/mentalray/include/BA_color_switcher.mi
// loading /autodesk/maya2008/mentalray/lib/BA_color_switcher.so
// parsing /autodesk/maya2008/mentalray/include/BA_dof.mi
// loading /autodesk/maya2008/mentalray/lib/BA_dof.so
// parsing /autodesk/maya2008/mentalray/include/BA_illum_flat_light.mi
// loading /autodesk/maya2008/mentalray/lib/BA_illum_flat_light.so
// parsing /autodesk/maya2008/mentalray/include/BA_illum_rgb_shadow.mi
// loading /autodesk/maya2008/mentalray/lib/BA_illum_rgb_shadow.so
// parsing /autodesk/maya2008/mentalray/include/BA_illum_visbool.mi
// loading /autodesk/maya2008/mentalray/lib/BA_illum_visbool.so
// parsing /autodesk/maya2008/mentalray/include/BA_integer_switcher.mi
// loading /autodesk/maya2008/mentalray/lib/BA_integer_switcher.so
// parsing /autodesk/maya2008/mentalray/include/BA_light.mi
// loading /autodesk/maya2008/mentalray/lib/BA_light.so
// parsing /autodesk/maya2008/mentalray/include/BA_scalar_clamprange.mi
// loading /autodesk/maya2008/mentalray/lib/BA_scalar_clamprange.so
// parsing /autodesk/maya2008/mentalray/include/BA_scalar_modulus.mi
// loading /autodesk/maya2008/mentalray/lib/BA_scalar_modulus.so
// parsing /autodesk/maya2008/mentalray/include/BA_shadow_falloff.mi
// loading /autodesk/maya2008/mentalray/lib/BA_shadow_falloff.so
// parsing /autodesk/maya2008/mentalray/include/BA_texture3d_warp.mi
// loading /autodesk/maya2008/mentalray/lib/BA_texture3d_warp.so
// parsing /autodesk/maya2008/mentalray/include/BA_texture_cell3d.mi
// loading /autodesk/maya2008/mentalray/lib/BA_texture_cell3d.so
// parsing /autodesk/maya2008/mentalray/include/BA_texture_fractal4d2.mi
// loading /autodesk/maya2008/mentalray/lib/BA_texture_fractal4d2.so
// parsing /autodesk/maya2008/mentalray/include/BA_texture_oily_specular2.mi
// loading /autodesk/maya2008/mentalray/lib/BA_texture_oily_specular2.so
// parsing /autodesk/maya2008/mentalray/include/Dirtmap.mi
// loading /autodesk/maya2008/mentalray/lib/Dirtmap.so
// parsing /autodesk/maya2008/mentalray/include/architectural.mi
// loading /autodesk/maya2008/mentalray/lib/architectural.so
// parsing /autodesk/maya2008/mentalray/include/base.mi
// loading /autodesk/maya2008/mentalray/lib/base.so
// parsing /autodesk/maya2008/mentalray/include/contour.mi
// loading /autodesk/maya2008/mentalray/lib/contour.so
// parsing /autodesk/maya2008/mentalray/include/ctrl_irradiance.mi
// loading /autodesk/maya2008/mentalray/lib/ctrl_irradiance.so
// parsing /autodesk/maya2008/mentalray/include/mix8layer.mi
// loading /autodesk/maya2008/mentalray/include/mix8layer.so
// parsing /autodesk/maya2008/mentalray/include/paint.mi
// loading /autodesk/maya2008/mentalray/lib/paint.so
// parsing /autodesk/maya2008/mentalray/include/physics.mi
// loading /autodesk/maya2008/mentalray/lib/physics.so
// parsing /autodesk/maya2008/mentalray/include/production.mi
// loading /autodesk/maya2008/mentalray/lib/production.so
// parsing /autodesk/maya2008/mentalray/include/subsurface.mi
// loading /autodesk/maya2008/mentalray/lib/subsurface.so
// parsing /autodesk/maya2008/mentalray/include/surfaceSampler.mi
// loading /autodesk/maya2008/mentalray/lib/surfaceSampler.so
updateRendererUI;
// Error: Object not found: mainRenderMenu //
// Error: Object not found:  //
// Error: Object is not a child: Custom //
Co się stało?
  • Wyświetleń 1,1k
miałem taki błąd gdy przenosiłem ikonki shelfowe do innego folderu
problem był w ścieżce dostępu do ikonki skopiowałem z windowsa a majka lubie odwrócone \ ale majka się uruchomiła tyle że w shelfowych plikach / zniknęłu całkowicie i ikonki na shelfie też już się nie pojawiały, poprawiłem to ręcznie w notatniku i było oki, spróbuj zrobić to samo:)
Ale w którym pliku to zmienić?
Poszukjałem
Podmieniłem pliki konfiguracyjne na styare z 8.5 powiedziało że ma nowe zestawy i zapytało czy wgrać. Kliknąłem Update i DZIAŁA:]
Już miałem reinstalować, dzięki za pomoc bo pewnie niezbyt szybko wpadłbym na pomysł zabawy plikami konfiguracyjnymi sam. Dałbym ci repa, ale już nie mogęł:]
Chyba miałem jakąś grubszą awarię twardziela, część plików nie działa.
