Estimator analisys_fotony
Jo
Ostatnio tez probowalem poddawac analizie kilka scen, niestety brak mi wiedzy na temat ja brazil analizuje i co oznaczaja poszczegolne kolory. Troche to pewnie mialo przypominac analize w MR, ale jak narazie dla mnie to czarna magia.
Analizowaliscie juz moze ??
Fotoas
  • Wyświetleń 1,6k
fotoas poczytaj instrukcje!!! Tam pisze jak byk o tym.
Zreszta po poziomie merytorycznym(czytaj bardzo kiepskim) twoich tutoriali wnioskuje iz totalnie olewasz manuala :(
Przykre to ze piszesz i miotasz sie w rzeczach bez podstaw \"teoretycznych\" :((( Stary tak nie mozna :((((
specjalnie dla Ciebie cytat:
4.9.6.1 Estmator
4.9.6.1.1 Basic
The simplest estimator possible, and therefore the fastest. There
are only a few cases where this is useful, however, it can
potentially be used with regathered global photon maps to gain a
bit of speed, and will work well with caustics that are deposited
onto low detail surfaces with no bump map. This estimator does
not support thin surface culling. Photons that strike the opposite
side of a thin surface will bleed light through the surface if the
search radius for the estimate is larger than the thickness of the
surface. This estimator does not support shading effects on bump
mapped receiving objects, and will not generate specular highlights
on any materials.
4.9.6.1.2 Advanced
This is the default, full featured irradiance estimator. It does not
allow photons that strike from the opposite side of the surface to
affect the irradiance estimate, which limits some cases of light
bleeding, particularly when photons strike the back of a thin
object. It supports shading affects on bump mapped receiving
surfaces (you will see the bump map shading even if the only light
is coming from the photon map), and it will generate specular
highlights. The highlights are currently only supported on the
Brazil BasicMtl, as this was the test bed for developing the api.
The highlights will also have quantization banding patterns on flat
surfaces due to photon direction being compressed.
4.9.6.1.3 Analysis
Intended to help adjust the general irradiance estimate settings
(particularly search radius and the number of photons), this
estimator returns various color values based on specific
information in the photon map. The information being returned is
still being changed internally, as we are trying to determine the
most useful feedback. Currently, the most useful channel is the
Red color channel, which returns the approximate error in the
estimate. Areas with no red either found all the photons required
for the estimate, or found less than the hardcoded minimum (8).
Brighter red indicates fewer photons. As the red drops in value,
that means the found photon count is approaching the specified
estimate count. The goal is to have as little red as possible in areas
where the photons energy is very bright, while keeping the Max
Search Radius as small as possible.
4.9.6.2 Specular
Enables/disables the advanced irradiance estimates support for generating specular
highlights from photon map illumination (specular receivers)...e.g. caustics will
create highlights on objects.
Brazil r/s V1.2 Reference Manual
4.9 Photon Map Parameters 56
Jiggle, mysle ze fotoasowi chodzi o rozszerzenie zadanienia ponad to co zostalo napisane w manualu, wymiane doswiadczen i cokolwiek na rzeczy. Manuala to kazdy sobie moze przeczytac.
Tomek Januszkiewicz to swietnie ze uwazasz iz jest w Polsce ktokolwiek posiadajacy wieksza wiedze na temat Brazila niz ta zawarta w manualu, kto udzielaby sie na tym forum.
No chyba ze jest tutaj klub \"gdybaczow\" i notorycznego fantazjowania ;)
wieksza wiedze??
chodzi o doswiadczenie, jakie doswiadczeniie przekazuje ci manual? bo mi zadne
Jiggle_ widze ze czytales juz pewnie nie raz instrukcje do brazila i zapewne nie ma przed toba on zadnej tajemnicy.Badz tak uprzejmy i mi wytlumacz jak przeanalizowac scene .Bede ci dozgonnie wdzieczny. Bo manual to co innego a doswiadczenie to co innego.Dzieki ze zasmiecasz forum manualek ktorego ma kazdy na kompie, ale mi raczej chodzilo o konkretne uwagi na ktore widac cie nie stac.. a w nieboglosy krytykujesz moja wiedze na temat Brazila niepotrafiwszy wczuc sie w sens wątku.
gratuluje elokwencji
jestes nasza gwiazda od dzis :)
i prosze nie mow do mnie \"stary\' bo jeszcze ludzie pomysla ze sie znamy osobiscie :o
Fotoas
Analiza padania fotonow w Brazilu jest podobna do innych renderow.
Najwazniejszy kanal kolorow to oczywiscie czerwony, ktory oznacza on bledy w obliczeniach :)
Ciemny czerwony: brak obliczonych fotonow w obszarze
Jasny czerwony: zbyt mala liczba fotonow w obszarze.
Pozostale kanaly z tego co zaobserwowalem:
Zółty i niebieski:
Zółty (chyba, tego nikt nie wie poza tworcami :D) to sa obszaer o najwiekszej energii i liczbie fotonow.
Im jasniejszy zolty tym jest tego wiecej.
Zolty kolor to fotony z 1 odbiciem, tzw \"pierwotne\" prostos z swiatla:)
Niebieski: odbite fotony, im ciemniejszy tym bardziej wygasle i z mniejsz liczba odbic. :).
Wane aby testy takie tobic na jednolitych materialach, np bialy, gdyz Brazil w anlisys uwzglednia kolor bleeding :)
Czyli najlepiej aby bylo jak najnajmniej czerwonych kropek, reszta kolorow zalezy od sceny :)
to by bylo na tyle w tym temacie...
OT: Fotoas pomije twoje zgryzliwe docinki :D Dosc ich mam z forum3d.
Jiggle_ robiles kiedys taki test ?? czy tylko bawisz sie w tlumacza manuala z angielsko na poski ??
nie da sie ukryc ze te trzy ostatnie watki napisalem by rozbudzic dyskusje, a przy analizie nie wiem czemu ale mi nigdy jeszcze sie nie pojawily zadne czerwone kropki.. moze kiedys raz..dlatego piszac ze nie mam na temat analizy zadnego pojecia mialem na mysli \'czemu nie widze tego co powinienem\'
moze ktos sieknie jakas ambitna analize tu na forum.. takie krok po kroku..ala_mini_tutor_jalle\'s
Jiggle masz znakomita okazje zaprezentowac ze nie czytasz tylko manuala ale kumasz baze,czacze, rumbe.. i inne balety z brazilem :)
PS: nie docinam ci tylko proboje wykorzenic nabyta z niewiadomo kad sklonnosc do osobistych wedrowek po kims innym z forum odbiegajac przy tym znacznie od tematu ,zagadnienia, zagwostki, zadania, ...
FotoAs
