Terragen 2
W koncu po wielu latach prac ujrzala swiatlo dzienne druga wersja rewelacyjnego programu do tworzenia krajobrazow (a nawet calych planet) - Terragen.
Lista cech pakietu wyglada nastepujaco:
-Hybrid micropolygon renderer optimised for large displacements and very large landscapes.
-Render entire planets, sweeping vistas, tiny rock gardens, or anything in between.
-Export high resolution objects from displaced surfaces.
-Import 3D objects for rendering.
-Render millions of plants and other objects using instancing. Billions of virtual polygons are handled with ease.
-Add multiple heightfields, textures and displacement maps to your scene.
-Georeferencing options; automatic georeferencing for properly formatted GeoTIFF files.
-Procedural terrains that can span an entire planet.
-Apply almost "infinite" fractal detail to terrain and other objects.
-Overhanging terrain using procedural displacements, image-based displacements, or imported geometry.
-3D painting of colours and masks that can control almost anything in the scene.
-Photorealistic atmosphere and sunlight.
-Volumetric clouds or fast "2.5D" clouds.
-Global illumination, multiple scattering in volumetrics, full light interaction between volumetrics and surfaces.
-Production quality anti-aliasing and motion blur that renders quickly and efficiently.
-High dynamic range output; generate photorealistic environment maps and IBL sources.
-Node graph editor for ultimate control over shaders and textures.
-Flexible planetary shading pipeline.
-Animation of almost any parameter with the optional Animation module.
Wiecej informacji na stronie producenta.
  • Wyświetleń 1,6k
Prezentuje sie niesamowicie, szczegolnie ze nie jest drogi. Ciekawe jak prezentujer sie import/export w praktyce. Trzeba chyba demo zassac :D
Ciekawie to brzmi, jeśli dobrze zrozumiałem to można robić całe planety na tym. Ludzie robiący kosmiczne scenerie mogą nieźle na tym skorzystać...
Tylko trochę taka gorzka myśl - do czego to wszystko zmierza... Zaniedługo będą generatory na wszystko, miejsca na twórczą inwencję robi się coraz mniej...
Hu hu, w koncu wydali, pamietam jak lata temu bawilem sie Terragenem 1. Ladnie to wyglada.
SBT: generatory generatorami, ale z tego co pamietam to w 1 trzeba bylo niezle sie nameczyc zeby to wygladalo jako tako.
Pamiętam moje zabawy Dreamscape'm. Zrobienie porządnego terenu ze wszystkimi bajerami, erozją itp prawie kompletnie zamulało mi pamięć. Ciekawe, jak to jest w tym przypadku?
Terragen to nie Vue i niestety terenu sie tam nie modeluje. Mozna jedynie proceduralny displacement dodac, lub wygenerowac teren calkowicie proceduralnie ale srednio to wyglada. Program bazuje niestety glownie na imporcie terenu. Z tego co zdazylem sprawdzic to nie ma chyba renderingu buforow co sie troche dziwne wydaje i raczej ogranicza wykorzystanie programu.
