Ot - taki sobie pomysł na narzędzie.
Może ktoś będzie miał jakąś dobrą ideę jak to rozwijać dalej:
$sel = `ls -sl`;
$joint = $sel[0]; // selected joint
$childs = `listRelatives -c $joint`;
$childJoint = $childs[0]; // his first child joint
$conn = `listConnections -t "skinCluster" $sel[0]`; //this is a first skin cluster connected to the joint
$meshes = `listConnections -t "mesh" $conn[0]`; // meshes connected to the joint
$vertsNum = `polyEvaluate -v $meshes[0]`; // number of a verts in a mesh
string $influencedVerts[]; // influenced verts init
float $subJointsNum = 5; // number of subjoints (later to be controlled with a passed argument
float $vertDots[]; // dot products of vertex  joint vectors. Needed to estimate the position against the joint's X-axis.
$jointPos = `xform -q -ws -t $joint`;
$childPos = `xform -q -ws -t $childJoint`;
float $vecX = $childPos[0] - $jointPos[0];
float $vecY = $childPos[1] - $jointPos[1];
float $vecZ = $childPos[2] - $jointPos[2];
vector $jointVector = >;
string $newSkinJoints[];
$newSkinJoints[0] = $joint;
// CREATE SUBJOINTS
for ($a = 1; $a 	$njX = ($vecX * ((1 / $subJointsNum) * $a)) + $jointPos[0];
$njY = ($vecY * ((1 / $subJointsNum) * $a)) + $jointPos[1];
$njZ = ($vecZ * ((1 / $subJointsNum) * $a)) + $jointPos[2];
$roo = `joint -q -roo $joint`;
$o = `joint -q -o $joint`;
$rad = `joint -q -rad $joint`;
$newJoint = `joint -p $njX $njY $njZ -roo $roo -rad $rad[0] -n ($joint +"_"+$a + "_rotator")`;
//-o $o[0] $o[1] $o[2]
$newSkinJoints[size($newSkinJoints)] = $newJoint;
$newSkinJoints[size($newSkinJoints)] = $childJoint;
parent $newSkinJoints[size($newSkinJoints) - 1] $newSkinJoints[size($newSkinJoints) - 2];
// LOCK ALL INFLUENCES EXCEPT THE SPLITTED JOINT
$influ = `skinCluster -q -inf $conn[0]`;
for ($inf in $influ){
setAttr ($inf + ".liw") 1;
setAttr ($joint + ".liw") 0;
//setAttr ($childJoint + ".liw") 0;
// ADD INFLUENCES TO THE SKIN CLUSTER
for ($a = 1; $a 	skinCluster -e -wt 0 -ai $newSkinJoints[$a] $conn[0];
//REGISTER ALL INFLUENCED VERTS IN ONE ARRAY
for ($a = 0; $a 	$val = `skinPercent -t $joint -q $conn[0] ($meshes[0] + ".vtx[" + $a + "]" )`;
if ($val > 0) $influencedVerts[size($influencedVerts)] = $a;
for ($vertNum in $influencedVerts){
$vertPos = `xform -q -t -ws ($meshes[0] + ".vtx[" + $vertNum + "]")`;
float $vertPosX = $vertPos[0] - $jointPos[0];
float $vertPosY = $vertPos[1] - $jointPos[1];
float $vertPosZ = $vertPos[2] - $jointPos[2];
vector $vertVector = >;
$vertDot = `dot $jointVector $vertVector`;
$jointVecMag = `mag $jointVector`;
if ($jointVecMag > 0){
	$vertDot = $vertDot / $jointVecMag;
	$vertDots[size($vertDots)] = $vertDot;
$vertexJointNum = $vertDot / (1 / $subJointsNum);
float $floorJoint = `clamp 0 (size($newSkinJoints) - 1) (floor($vertexJointNum))`;
float $easeVal = $vertexJointNum - $floorJoint;
int $floorInt = $floorJoint;
int $floorIntClamp = `clamp 0 (size($newSkinJoints) - 1) ($floorInt+1)`;
float $vtxBaseWt = `skinPercent -t $newSkinJoints[0] -q $conn[0] ($meshes[0] + ".vtx[" + $vertNum + "]")`;
skinPercent -tv $newSkinJoints[0] 0 $conn[0] ($meshes[0] + ".vtx[" + $vertNum + "]");
skinPercent -tv $newSkinJoints[$floorInt] ($vtxBaseWt - ($vtxBaseWt * $easeVal)) $conn[0] ($meshes[0] + ".vtx[" + $vertNum + "]");
skinPercent -tv $newSkinJoints[$floorIntClamp] ($vtxBaseWt * $easeVal) $conn[0] ($meshes[0] + ".vtx[" + $vertNum + "]");
  • Wyświetleń 1,1k
no ok, szacun, tylko po co ? maya to jeden wielki majdan, ktory niebawem sie wykrzaczy, tylko na to czekam, ale masz 5+
nie wiem czy nie zauważyłeś ale ten "majdan" to wciąż jedyne słuszne narzędzie do animacji przy pełnych metrażach i szybko się to nie zmieni.
pffff..... to mi argument zes znalazl, ze wszyscy jezdza na zimowkach latem to znaczy ze i ty musisz ? masz potencjal nie marnuj go,
Hmmm, czy mi sie zdaje, czy w Majce jest juz narzedzie do zmian w szkielecie po zeskinowaniu?
to bedzie w 2015
