witam
nie wiem jak sie odczytuje kody zawarte w nazwach plikow zwiazanych z tekstura
np:
xxxxx _b005.xxx
xxxxx _d100.xxx
xxxxx _s050-g025.xxx
prosba o pomoc
  • Wyświetleń 1,3k
zwykle nikt nie koduje textur ;)
jakbym mial strzelac to masz tutaj info zeby:
wrzucic do slotu Bump i dac sile bumpa na 5%
wrzucic do Diffuse na 100%
do specular na 50% i glossiness na 25%
chyba ze to jakis mega tajny kod tylko dla Lightwavea
Info z FAQ producenta textur
http://www.arroway-textures.com/en/faq/14
What do notations like _b030 or _s050-(g025) in map filenames mean?
We understand, that our naming convention for map files can seem confusing at first glance. Here is how to read them:
Every notation consists of a char specifying the channel, as well as three digits containing a numerical setting. - x###
The first notation gives the primary purpose of a map. - name_x###
For some map several purposes might be specified. - _x###_y###_z###
Parenthesis remark a fixed value. - (x###)
Channels:
D - Diffuse color, B - Bump, P - Displacement, S - Specularity, G - Glossiness, R - Reflectivity, O - Opacity, A - Anisotropy.
Some examples:
d100: "This is the diffuse color map of the texture; to be used at full channel effect strength"
b030: "This is the bump map; the recommended strength is 30%."
s050: "The specularity map; the recommended strength is 50%."
(g025) "Instead of a map, you may specify a fixed glossiness value of 25%."
p010: "The displacement map; real-world relief depth is 10mm."
With this notation you can see directly what a map is, how it relates to other maps and what recommended setting are - all without the need to consult the catalog.
