Wideoprezentacje modo 501
  • Wyświetleń 2,3k
Dzieki wielkie - i jeszcze ten japonski - dodatkowa atrakcja :D Bardzo ciekawym co dodali do "moderingu", jak to uroczo przetlumaczyla pani :D
Podziekowac, ale chyba musze poczekac na oficjalne filmiki od luxology, cos ten ustream mi strasznie rwie.
No dobra, no to macie prawdziwą zajawkę z Paryża (2 października), prowadzoną przez samego Peeblera. Prawie 3h oglądania! Bon Appétit! ;)
Lista nowości (nieoficjalna):
Modeling, Sculpting and UV mapping improvements
- Pixar Subdivision - yeah, you've seen it, but it's still just so cool!
- UV Distortion view
- Preserve curvature with slice tools
- Add loop tool
- Add point tool
- Edge extend and slide now work with background constraints
- Symmetrical linear falloff
- RayGL – renders preview in any viewport
- Smoothing groups
- Select diagonal edges –convert tris to quads by deleting these edges
- Snapping tools improved – now part of the tool pipe, can be saved as tool preset, hold X key to temporarily disable
- Multi-res sculpting
- New sculpting brush presets
Animation improvements
- Animation setup – nodal view, many new modifiers including conditional
Many general UI enhancements
- Create project directories
- Lock items – very useful for nailing down a camera so it’s not accidently keyed
- New color picker – very full featured, think Kuler inside a floating window in Modo
- Totally new help system – F1 actually works!
Rendering improvements
- Preview render is much faster
- Extended render pass – bake a render until you’re happy with it
- Current layer overlay – select an item in the shader tree and see how that layer is affecting your render
- Preivew under the cursor – essentially you can paint your preview render in the areas you are most concerned about
- Fur can be disabled in the preview
- Rendering is 2-3 times faster and in many cases looks better
- New bump mapping – behaves like displacement, looks much better than traditional bump, value based on distance instead of percentage
- DOF looks to be vastly improved, graininess nowhere to be found
- Bokeh effects – control over aperture shape
- View frustum culling for fur – if camera doesn’t see it, it’s not calculated
- Displacement as bump – honestly, didn’t fully understand this one, but it looked fantastic and required less memory than traditional displacement
- OpenEXR tileable images – enables use of ginormous images within shader tree, example looked like Blue Marble imagery – ~10GB image on a globe
- Hair guides – tip combing for better control over guides
- Occlusion textures – this is very cool, AO is now a texture item in the shader tree, so no need to bake out for use as a layer mask etc. Many new parameters to control of the look of the AO as well.
- Ability to texture a single poly on both sides with two separate textures – example shown was a label on a bottle
SDK available to developers
- Procedural geometry example – gear created, all parameters controlled (spoke, teeth, etc.) – can also be frozen to mesh
- Procedural trees being developed by third party
- ~120 new procedural textures – some very cool ones shown off included snake scales and veins
- Bullet dynamics engine coming from third party developer – examples looked fantastic!
Also
- Freeze replicators to mesh items
- Bake replicator point sources to mesh
- Motion vector output via OpenEXR
- Default environment no longer looks like cartoon world
- Materials respect embedded image alpha
- Render outlines – not quite wireframe render, but has a lot of cool controls including line thickness and depth falloff
- Search within shader tree and item list – filtering works as it does currently in command history palette
I pewnie więcej drobnych, ale umilających i przyspieszających prace dodatków.
"Emisja" programu przewidziana na koniec roku (bieżącego ;)
Moze to i to samo ale w czesciach i nie trzeba sciagac duzo zeby zobaczyc co nas interesuje:
Schematic View:
http://www.luxology.com/video/view.aspx?id=596
Modeling enhancements:
http://www.luxology.com/video/view.aspx?id=589
Assembly Groups:
http://www.luxology.com/video/view.aspx?id=597
Multi-Resolution Sculpting:
http://www.luxology.com/video/view.aspx?id=594
Pixar SDS:
http://www.luxology.com/video/view.aspx?id=586
http://www.luxology.com/video/view.aspx?id=587
Snapping enhancement:
http://www.luxology.com/video/view.aspx?id=593
Rendering features:
http://www.luxology.com/video/view.aspx?id=599
Mnie jak zwykle zainteresowal sculpt. Jesli jest tak dobrze jak na filmikach to biedny mudbox :D
