Rendering Completed
Stawiam nowa scene i wrzucam sphere i nakladam na nia mia_materila_x.
Sphera w vieporcie robi sie zielona nigdy tak nie mialem;/. No nie moge batch'a puscic bo rendering konczy sie z miejsca. W mayaRenderLog dostaje takie cos:
Starting "C:\Program Files\Autodesk\Maya2011\bin\mayabatch.exe"
Warning: line 1: Unrecognized node type for node 'mia_material_x_passes1'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'mentalrayItemsList'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'mentalrayGlobals'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'miDefaultOptions'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'miDefaultFramebuffer'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'PreviewImrRayTracyOff'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'PreviewImrRayTracyOn'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'miContourPreset'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'Draft'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'DraftMotionBlur'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'DraftRapidMotion'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'Preview'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'PreviewMotionblur'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'PreviewRapidMotion'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'PreviewCaustics'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'PreviewGlobalIllum'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'PreviewFinalGather'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'Production'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'ProductionMotionblur'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'ProductionRapidMotion'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'ProductionFineTrace'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'ProductionRapidFur'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'ProductionRapidHair'; preserving node information during this session.
File read in 0 seconds.
Result: C:/Users/ksalek/Documents/maya/projects/default/scenes/untitled__5472.mb
Error: The renderer mentalRay is not registered yet.
Error: Scene C:/Users/ksalek/Documents/maya/projects/default/scenes/untitled__5472.mb failed to render.
// Maya exited with status 210
Mial ktos cos trakiego. Mile widziane jakiekolwiek sugestie
  • Wyświetleń 1,4k
Cześć Krzychu
Może te linki pomogą, chyba coś nie tak z mental rayem i jego ładowaniem w Maya.
http://forum.cgpersia.com/f32/maya-2011-batch-render-problem-14305/
"1. Set the project correctly
2. run [Rendering] Render->Run Render Diagnostics
3. check the render logs after increasing verbosity to level 5
4. check the memory (what does the MEL command memory -sum; return when the scene is
loaded?)
5. import your scenes into a new clean scene
6. optimize scene file
7. try command line like C:\render -r mr tits.mb"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13391312&linkID=9242258
czaps
Siemanko Czapsu
Sprawdzilem wszystko poza tym linkiem z forum. Zrobie to jutro.
Na ta chwile wszystkiwe podpunkty zrobilem (nie wiem o co chodzi w 3cim)
To co jest ze strony autodesku nie zalicza sie bo nei mam textur. to nowa scena z kulka.
Jak odpalam mayke (pusta scena) i ładuje mentala dostaje takic cuda w edytorze.
// mental ray Node Factory: unloaded // mental ray for Maya 2011 //
// Mental ray for Maya: using startup file C:/Program Files/Autodesk/Maya2011/mentalray/maya.rayrc.
// mental ray for Maya: setup //
// mental ray for Maya: initialize //
// mental ray for Maya: using 1 license //
// mental ray for Maya: register extensions //
// mental ray Node Factory: loaded
// mental ray for Maya: successfully registered //
// mental ray for Maya: loading startup file: C:/Program Files/Autodesk/Maya2011/mentalray/maya.rayrc //
// parsing C:/Program Files/Autodesk/Maya2011/mentalray/include/AdskShaderSDKWrappers.mi
// generating Maya nodes...
// parsing C:/Program Files/Autodesk/Maya2011/mentalray/include/architectural.mi
// loading C:/Program Files/Autodesk/Maya2011/mentalray/lib/architectural.dll
// Error: $nodeType == "mip_card_opacity" || )
// Error: Syntax error //
// parsing C:/Program Files/Autodesk/Maya2011/mentalray/include/contour.mi
// loading C:/Program Files/Autodesk/Maya2011/mentalray/lib/contour.dll
ITD.......
EDIT:
Ok cos poszlo tzn zrobilem "COŚ" z tych rzeczy powyzej i jednak batch ruszył. Ale obiekty w scenie nadal pozostaja zielone jakby nie mialy materialu(o dziwo renderuja sie poprawnie).
Edytowane przez guru
