Windows XP - problem
witam wszystkich
mam taki problem z systemem otoz dzisiaj wyskoczyl mi pewien komunikat z bledem jakies tam aplikacji po jej awaryjnym zamknieciu system wylacza sie po 60 sek
co sie dziele ??
zrobilem reinstalke z formatem c, przeskanowalem caly komputer antywirusem 2004 i nic dalej to samo :( a wyskakuje mi ten komunikat po kilku minutach uzywania windowsa
pozmozcie z gory dzieki :)
  • Wyświetleń 1,5k
witam to znowu ja
pomoglo ale nie na dlugo dzisiaj znowu mam ten sam problem a te latki nie pomagaja, a aktualizacji windowsa nie mam jak zrobic bo co chwile sie wylacza macie jeszcze jakies \"lekarstwa\" ?? :(
Jeśli to sasser to zajrzyj tutaj:
http://securityresponse.symantec.com/avcenter/venc/data/w32.sasser.b.worm.html
Kawałek z tego artykułu:
\"What to do if the computer shuts down before you can patch or get the tool
This threat can cause Windows to keep shutting down and restarting. This can prevent you from installing the Microsoft patch or downloading the tool described below. To prevent the shut down, do the following. (You may have to try this several times, as you only have about 20 seconds to do steps 3 to 6.) (This will not work on Windows 2000.)
Disconnect the computer from the network/Internet connection. (Disconnect the cable if necessary.)
Restart the computer.
As soon as Windows opens and you see the Windows desktop, click Start > Run.
Type:
cmd
and press Enter.
Type:
shutdown -i
and press Enter.
In the Remote Shutdown Dialog that opens, do the following:
Click Add and type your computer name into the appeared window. Then click OK.
In the \"Display warning for Seconds\" field, type 9999 in place of the default value of 20.
Type any message in the Comment box.
Click OK.
Reconnect the network/Internet connection.
Connect to the Internet, and get the patch. Then continue with the steps described below.
This gives you about three hours to get the patch installed, update the definitions, and so on.
When you have patched for and removed the threat, you can re-enable the 20-second default warning if you want to.\"
[Wyedytowany dnia 7-7-2004 > MRCN]
