VRAYforC4D v3.25
Została zapowiedziana nowa wersja VRAYforC4D v3.25, a w niej między innymi:
New great V-Ray 3 render speed. faster ray tracing and render performance; all parts of V-Ray had been greatly optimized using state of the art ray tracing technology. you see the same render speed as in newest V-Ray Max3.25
New progressive sampler rendering: see your render within seconds instead of waiting for buckets
Dynamic Bucket splitting
New default universal render setup for path tracing (BFLC) and IRLC based work, which eliminates the need to set or tune any light or material subdivision, or DMC settings (all done by the V-Ray core). biased and unbiased ray tracing methods for choice.
Fast IPR window (interactive preview render): based on V-Ray RT v3 (cpu or gpu for choice)
V-Ray RT production rendering in picture viewer and editor
RT Lightcache support
multifacetted GTR BRDF (ggx pro with tail control)
Min shading rate (can replace subdivision control within one single slider)
v3 max ray intensity setting (can speed up rendering)
Lot faster hair, grass & fur rendering
Lot faster instance and proxy rendering
Embree 2.3 (also dynamic geometry like displacement ,hair, mb, proxies)
Probabilistic light sampling:a lot faster rendering with huge number of area lights
Render masks
V-Ray Clipper (make easy render time sections of objects or groups of objects)
Reflection/refraction sets (include /exclude lists)
New Object based and unbiased/raytraced (still fast) subsurface scattering option in SSS2 mat and channel, RT compatible
V-Ray Skin material
V-Ray Volume material
New static displacement options (faster)
Udim textures**
Tiles exr and tiff loading (load /unload buckets of bitmaps on demand to save ram)
Open exr2
Separate light select layers for render elements (V-Ray light select)
Deep image saving
Sampler-Info-Tex shader as in V-Ray Maya, to read out scene data and use for shading
OSL shader and OSL material
New disk area light
V-Ray frame buffer,with ICC, .OCIO, LUT, .cube, interactive burn,exposure,highlight, color balance controls (for sure in windows, for OSX depends yet on the V-Ray sdk, for OSx it might come in SP)
Lens effects
New vrmesh export, with all features, animated vrmeshes, hair and particles in vrmeshes
Vrscene node (loading external vrscene files on render time)**
Vray metaball surface,
Open subdiv support
Additional vray shaders (vray curvature, vray ray switch, vray user data color, vray user skalar, bercon noise)
Clip opacity feature for faster cutout alphas
Optimised volume rendering
New LC feature for animation
Support for OpenVDB, Field 3d and Vray Volume grid**
Improved translucency in 2 sided mat
New Dr features (add & release nodes while render, exclude local machine from render)
Cache geometry and textures**
Quick setup
Simplified user interface (optional like vray 3 max)
Faster material & shader preview & GUI
Support for V-Ray stereo cameras
Support for 6x1 cubic stereo VR cameras (for Oculus Rift use p.e https://www.oculus.com/en-us/rift/)
New Spherical Panorama stereo camera
Support for sub folders in c4d search paths
Bitmap aperture & optical vignetting in V-Ray physical camera
Shademap support for stereo images(speeds render up)
OGl resolution options for bitmaps in editor
V-Ray presets, V-Ray tool bar
V-Ray Node based Material editor (in SP)
MAXON Team Render still image splitting support
Beta testy powinny ruszyć w tym miesiącu, a nowa wersja dostępna jeszcze w tym roku.
Powstał też nowy kanał na YT, na którym będą pokazywane sukcesywnie nowości dot. tej wersji:
https://www.youtube.com/channel/UCuzQFgPDSAeUnYSKf4HFqfA
  • Wyświetleń 4,8k
