scena3d:skylit lobby and staircase
pradipta
Rekomendowane odpowiedzi
  • Odpowiedzi 22
Hi,
I see it's not scanline now like always ;)
good lighting , for this small lamps (white points) try too add IES maps.
don't like the floor reflection and wall shader (i think it isn't standart?).
Scene is too empty but it's WiP...add any little trees , flowers...add some life for this scene , maybe some vector or rpc people.
greets.
Odnośnik do komentarza
Udostępnij na innych stronach
It's a bit too clean. A bit to lifeless. A bit too cold. Try do bring some life to your scene. Make it a bit warmer and softener. It's clean that I it seems not real. Do some fog, dust or something. As for modeling you got the highest notes :) Looks good
Hi, didn't like the ground texture(parquet or smthg ?) and chairs on the left part of the image (imo they are to small) perhaps like lighting and design but theres a little bug on the top of image(left corner) - for this moment can give u 4stars ;)
thanks for all the feedback,
agmakonts: thanks, i understand that. i will try to improve on that on my next render
chveti: yes, for interior i started using vray now. ok, i tried IEs but never got satisfied result so i changed back to normal light. yes, i will ad some more objects to fill the space
illly: thanks. i will work on those thnigs.
hindus: yes, thanks for noticing the bug for me. i overlooked that. i will change the chair amd well, wall texture is bothering me alot.
thanks for your time,
hey pradipta, really nice rendering of very interesting architecture.
few tips:
1. do not use shitty rpc`s for such a nice shoot :)
2. if you use rpc check their scale vs chairs vs architecture
3. use camera correct modifier
4. never use pure white material because it always looks dirty (ceiling)
5. add color for skylight
look for the Zed's topic ...big hall...he's got vector humans in scene , people from photo sucks :P because you don't have on them good lighting etc.You can also try something like sansserif in his old scene , make LP people with standart shader without textures and details.
greets.
Hi Pradipta..hmmm...about work ? - remove those chairs and label(caption) on the bottom (to big font I think) - make smallest, finally make bigger render and should be better.
ps. sorry for my bad english ;)
Zarejestruj nowe konto
Zarejestruj się
Zaloguj się
Zaloguj się
  • Dodaj nową pozycję...
