czy w Mayi istnieje możliwość konwersji krawędzi wielokątu do krzywej?
  • Wyświetleń 901
Jest nawet do tego polecenie Modify/Convert/PolygonEdgesToCurve.
Ale ze czasem dziala to dosc dziwnie to lepiej uzyc takiego oto skryptu:
global proc string[] mm_curveFromEdges()
string $sel[] = `selectedNodes`;
if(size($sel)!=1)
error "Select some contiguous edges, on one poly object";
string $edges[] = `filterExpand -sm 32`;
int $len = size($edges);
if(!$len)
error "Select some contiguous edges";
string $infoVerts[];
string $fVerts[], $lVerts[];
int $position[], $sticks[], $firstHeadPos, $headsNr;
for($i=0; $i
$infoVerts = `polyInfo -ev $edges[$i]`;
$infoVerts = `stringToStringArray $infoVerts[0] " "`;
$fVerts[$i] = $infoVerts[2];
$lVerts[$i] = $infoVerts[3];
for($i=0; $i
$sticks[$i] = 0;
for($j=0; $j
if(($j!=$i))
if(($fVerts[$i]==$fVerts[$j]) || ($lVerts[$i]==$lVerts[$j]) || ($fVerts[$i]==$lVerts[$j]) || ($lVerts[$i]==$fVerts[$j]))
$sticks[$i]+=1;
if(($sticks[$i]2))
$firstHeadPos = 0;
$headsNr = 0;
for($i=0; $i
if($sticks[$i] == 1)
$headsNr++;
if($headsNr>2)
$firstHeadPos = $i;
int $orderedEdgesIDs[];
$orderedEdgesIDs[0] = $firstHeadPos;
int $currentEdgePos = $firstHeadPos;
int $jump = 0, $counter = 0, $max = size($edges)*size($edges);
while(size($orderedEdgesIDs)
for($i=0; $i
for($j=0; $j
if($orderedEdgesIDs[$j] == $i)
$jump = 1;
break;
if(!$jump)
if(($fVerts[$i]==$fVerts[$currentEdgePos]) || ($lVerts[$i]==$lVerts[$currentEdgePos]) || ($fVerts[$i]==$lVerts[$currentEdgePos]) || ($lVerts[$i]==$fVerts[$currentEdgePos]))
$currentEdgePos = $i;
$orderedEdgesIDs[size($orderedEdgesIDs)] = $i;
$jump = 0;
$counter++;
if($counter>=$max)
break;
int $forstOrLast = 0, $orderedVerts[], $oeLen = size($orderedEdgesIDs);
if(($fVerts[$orderedEdgesIDs[0]] == $fVerts[$orderedEdgesIDs[1]]) || ($fVerts[$orderedEdgesIDs[0]] == $lVerts[$orderedEdgesIDs[1]]))
$orderedVerts[0] = $lVerts[$orderedEdgesIDs[0]];
else if(($lVerts[$orderedEdgesIDs[0]] == $fVerts[$orderedEdgesIDs[1]]) || ($lVerts[$orderedEdgesIDs[0]] == $lVerts[$orderedEdgesIDs[1]]))
$orderedVerts[0] = $fVerts[$orderedEdgesIDs[0]];
for($i=0; $i
if(($fVerts[$orderedEdgesIDs[$i]] == $fVerts[$orderedEdgesIDs[$i+1]]) || ($fVerts[$orderedEdgesIDs[$i]] == $lVerts[$orderedEdgesIDs[$i+1]]))
$orderedVerts[size($orderedVerts)] = $fVerts[$orderedEdgesIDs[$i]];
else if(($lVerts[$orderedEdgesIDs[$i]] == $fVerts[$orderedEdgesIDs[$i+1]]) || ($lVerts[$orderedEdgesIDs[$i]] == $lVerts[$orderedEdgesIDs[$i+1]]))
$orderedVerts[size($orderedVerts)] = $lVerts[$orderedEdgesIDs[$i]];
int $ovLen = size($orderedVerts);
if($fVerts[$orderedEdgesIDs[$oeLen-1]] == $orderedVerts[$ovLen-1])
$orderedVerts[$ovLen] = $lVerts[$orderedEdgesIDs[$oeLen-1]];
$ovLen++;
else if($lVerts[$orderedEdgesIDs[$oeLen-1]] == $orderedVerts[$ovLen-1])
$orderedVerts[$ovLen] = $fVerts[$orderedEdgesIDs[$oeLen-1]];
$ovLen++;
string $ret[];
float $vertPos[] = `xform -a -ws -q -t ($sel[0]+".vtx["+$orderedVerts[0]+"]")`;
$curve = `curve -d 1 -p $vertPos[0] $vertPos[1] $vertPos[2]`;
if($orderedVerts[0] != $orderedVerts[$ovLen-1])
for($i=1; $i
$vertPos = `xform -a -ws -q -t ($sel[0]+".vtx["+$orderedVerts[$i]+"]")`;
curve -a -p $vertPos[0] $vertPos[1] $vertPos[2] $curve;
$ret[1] = "open";
else
for($i=1; $i
closeCurve -ch 0 -ps 0 -rpo 1 -bb 0.5 -bki 0 -p 0.1 $curve;
$ret[1] = "closed";
$ret[0] = $curve;
return $ret;
global proc string mm_extractCurveFromEdges(int $degree)
string $curve[] = `mm_curveFromEdges`;
if($degree == 1)
select -r $curve[0];
return $curve[0];
else if($degree == 3)
if($curve[1] == "open")
rebuildCurve -ch 1 -rpo 1 -rt 0 -end 1 -kr 0 -kcp 1 -kep 1 -kt 0 -s 4 -d 3 -tol 0 $curve[0];
if($curve[1] == "closed")
closeCurve -ch 1 -ps 0 -rpo 1 -bb 0.5 -bki 0 -p 0.1 $curve[0];
return $curve[0];
else
error ("Degree not suported: "+$degree+". Use only 1 or 3.");
//mm_extractCurveFromEdges 3;
global proc mm_extractCurveFromEdgesGUI()
if(`window -ex "mm_extCrvEdg_win"`)
deleteUI "mm_extCrvEdg_win";
window "mm_extCrvEdg_win";
columnLayout "mm_extCrvEdg_cLay1";
radioButtonGrp -nrb 2 -l "Degree" -l1 "Linear" -l2 "Cubic" -sl 2 -cw3 70 70 70 -p "mm_extCrvEdg_cLay1" "mm_extCrvEdg_rdb1";
rowLayout -nc 3 "mm_extCrvEdg_cLay1";
button -p "mm_extCrvEdg_cLay1" -l "Extract" -c "mm_extractCurveFromEdgesChooser `radioButtonGrp -q -sl \"mm_extCrvEdg_rdb1\"`; deleteUI \"mm_extCrvEdg_win\";" "mm_extCrvEdg_btn1";
button -p "mm_extCrvEdg_cLay1" -l "Apply" -c "mm_extractCurveFromEdgesChooser `radioButtonGrp -q -sl \"mm_extCrvEdg_rdb1\"`;" "mm_extCrvEdg_btn2";
button -p "mm_extCrvEdg_cLay1" -l "Close" -c "deleteUI \"mm_extCrvEdg_win\";" "mm_extCrvEdg_btn3";
window -e -wh 250 75 "mm_extCrvEdg_win";
showWindow "mm_extCrvEdg_win";
global proc mm_extractCurveFromEdgesChooser(int $degrSel)
switch($degrSel)
case 1:
mm_extractCurveFromEdges 1;
break;
case 2:
break;
default:
mm_extractCurveFromEdgesGUI;
Pozdr.
