Digimation Suite za darmo!
Digimation udostępnił za darmo zestaw 12 najlepiej sprzedających się pluginów do Maxa ;) [nie wiem czy to prawda :P]
Atomizer, which allows 3ds Max particle systems to use any 3D object as a particle.
Bones Pro, a powerful and easy to use skeletal deformation system.
Chameleon, which places textures based on the location of an animatable gizmo.
Clay Studio, an advanced metaball modeler.
DigiPeople, a collection of procedural, low-resolution mannequins.
Fractal Flow, which can be used to warp any image, video, or 3d object.
Glider, which can animate any object or particle along the surface of another object.
Lightning, a procedural electric arc generator.
MaxSculpt, advanced mesh sculpting with support for pressure sensitive tablets.
SandBlaster, the flexible particle system with a unique emitter and target system.
Spray Master, which can be used to spray geometry on, or around, other objects.
Tree Factory, used to generate a wide variety of trees and ground foliage.
link
link2
  • Wyświetleń 1k
Lightning? Ostatnia znana mi wersja chodziła na maxie 7, a potem nie było update'ów...
A mi chodzi o maxa 8 więc też jestem zaciekawiony jak to będzie.
EDIT już mam- źle patrzyłe z pośpiechu. Są wersję do 2008 ale 32 bit
