Maya dodawanie nowych shaderow - problem z bump combiner
mam problem z dodaniem shaderu, potrzeba jest zmienic plik maya.rayrc dodac linijke. Pliki pokopiowalem, wydaje mi sie tam gdzie trzeba. Dodaje shader do bryly i nie rendzi nic.... Anybody?
link "{MAYABASE}/lib/bumpCombiner.{DSO}"
mi "{MAYABASE}/bumpCombiner.mi"
link "{MAYABASE}/lib/mix8layer.{DSO}"
mi "{MAYABASE}/include/mix8layer.mi"
# Evaluated at startup time of the plug-in to fill the mental ray registry.
# mental ray registry entries set here will be applied
# in mental ray for Maya upon plug-in load. They may be used to
# adjust mental ray library search path to look for
# shader binaries in my local directory first
# registry "{_MI_REG_LIBRARY}" value "C:/myshader/Release;{MAYABASE}/lib" end registry
# define some useful registry variables
# registry "{MAYABASE}" value "/mentalray" end registry
# registry "{SYSTEM}" value "windows" end registry
# registry "{DSO}" value "dll" end registry
# mental ray registry commands within the _MI_MAYA_STARTUP key
# will be executed upon first rendering in mental ray only.
# registry "{_MI_MAYA_STARTUP}"
# value "mental ray startup upon rendering" # required, don't remove
# These commands are invisible to Maya, they may be used to
# load auxiliary libraries into mental ray, like image plug-ins.
# link "myimageformat.so"
# force some standard shaders into mental ray hidden to Maya
# (not using explicit directory path here when using network rendering)
# link “myshader.{DSO}”
# force the declaration of my shaders into mental ray, in case
# it was not loaded with mental ray for Maya Node Factory
# mi "C:/myshader/include/myshader.mi"
# echo "mental ray for Maya - custom startup done"
# end registry
# link "{MAYABASE}/lib/bumpCombiner.{DSO}"
# mi "{MAYABASE}/bumpCombiner.mi"
# link "{MAYABASE}/lib/mix8layer.{DSO}"
# mi "{MAYABASE}/include/mix8layer.mi"
Przy renderze wyskakuje. Plik jest wgrany podobnie biblioteka:
Warning: (Mayatomr.Custom) : C:/Program Files/Autodesk/Maya2009/mentalray/include/bumpCombiner.mi: couldn't find shader library //
Pytanie czy to tu {MAYABASE} powienienem zastapic
link "C:\Program Files\Autodesk\Maya2009\mentalray\lib/bumpCombiner.{DSO}"
mi "C:\Program Files\Autodesk\Maya2009\mentalray\bumpCombiner.mi"
link "C:\Program Files\Autodesk\Maya2009\mentalray\lib/mix8layer.{DSO}"
mi "C:\Program Files\Autodesk\Maya2009\mentalray\include/mix8layer.mi"
Edytowane przez Sebazx6r
  • Wyświetleń 1,1k
Generalnie tak, tylko zamień "\" na "/". ALe poprawniej byłoby zmienić environment variable - "MAYABASE" na poprawną ścieżkę.
# end registry
# end registry
link "C:/program Files/Autodesk/Maya2009/mentalray/lib/bumpCombiner.{DSO}"
mi "C:/Program Files/Autodesk/Maya2009/mentalray/include/bumpCombiner.mi"
link "C:/Program Files/Autodesk/Maya2009/mentalray/lib/mix8layer.{DSO}"
mi "C:/Program Files/Autodesk/Maya2009/mentalray/include/mix8layer.mi"
Znowu cos nie tak.
mental ray: got 8 satellite CPUs.
API 0.0 error 301031: call to undeclared function "bumpCombiner"
API 0.0 error 301036: while defining material "bumpCombiner1SG": undefined shader "bumpCombiner1"
Warning: (Mayatomr.Custom) : C:/Program Files/Autodesk/Maya2009/mentalray/include/mix8layer.mi: couldn't find shader library /
Chyba wina po stronie maya x64 bit ze nie dziala.
Wlasnie znalazlem ze nie trzeba nic zmieniac w Maya pow 8.5 w maya.rayrc. Tylko trzeba w Maya.env, ale to jeszcez sprawdze:
http://www.djx.com.au/blog/customizing-maya/
Wciaz jestem w kropce ;/.
Zrobilem tak jak tutaj. Pokopiowalem pliki do odpowiedniech lokacji:
put the AEbumpCombinerTemplate.mel in your docs/maya/6.0/scripts folder
put the render_bumpCombiner.xpm in your docs/maya/6.0/prefs/icons folder
put the bumpCombiner.fti in your "C:\Program Files\Autodesk\Maya2009\maya/icons folder
i
put the AEbumpCombinerTemplate.mel in your C:\Users\Sebastian\Documents\maya\2009-x64\prefs/scripts folder
put the render_bumpCombiner.xpm in your C:\Users\Sebastian\Documents\maya\2009-x64\prefs/icons folder
put the bumpCombiner.fti in your maya/icons folder
Nastepnie uruchomilem plugin kozystajac z info ze strony. I wciaz to samo. Wydaje mi sie ze plugin moze byc 32 bitowy.
http://mayastation.typepad.com/maya-station/2009/04/how-to-install-mental-ray-custom-shaders.html
Beny masz moze te shadery w wersji x64?
BUMP COMBINER x64 i inne shadery
Znalazlem bo kompilowac nie umiem:
http://www.box.net/shared/i6hd2271qk
Zaraz przetestuje.
DZiala bump combiner dla x64bit maya
Wstepny efekt bump na dielectric material, przez bump combiner.
