Maxwell render 1.5 juz w Maju
W Maju ukaze sie dlugo oczekiwana nowa wersja Maxwell Render 1.5 !!
Core enhancements: key parts of the engine have been rewritten, resulting in many fantastic improvements, bringing the quality of your renders to a completely new level. Memory handling has been greatly enhanced. This version uses much less memory than version 1.1, making it possible to render at very high resolutions (for example at 8000 x 6000 with less than 2 GB of Ram) without losing quality. High-res images are just a mouse-click away now.
Rozdzielczosc (16000x10669 px) do pobrania tutaj http://www.mikeverta.com/Posts/16k_Alien_Full.rar
As a consequence of the core enhancements, memory-intensive tasks such as glare, Multilight with a lot of emitters, large geometries and a lot of heavy textures are improved. Additionally, MXI files can always be re-rendered and the size of the MXI files is around 3.5 times smaller in the new version. The core enhancements also allow for a 32 bits output: it is now possible to set the output image format to HDR directly inside Maxwell Render. As already announced in previous newsletters, we have further improved the network system, making it more stable and faster, with the possibility to see a coop preview image and to select machines by name or IP. There will also be a Linux version, an optimized Maxwell Studio and an improved Maxwell Material Editor. Most of the plug-ins have been further improved and we will continue with these improvements in the coming months. For a preview of the upcoming Lightwave plug-in, see below. Yet still, these are just a few highlights of what the new version has to offer….We have many more surprises lined up for you, so stay tuned!
Wkrotce duzo wiecej :D
  • Odpowiedzi 28
  • Wyświetleń 8,8k
Nowy Maxwell Render o numerze 1.5 juz w Maju
Wiecej informacji w nastepnym tygodniu
Kurcze maxwella poznaję od paru dni a już się zakochałem. Już się nie mogę doczegać new one :)
Ej. Co jest z tym plikiem : 16k_Alien_Full.rar
Drugi raz już go zassałem i ciągle mam błąd przy rozpakowywaniu. Jak jest u Was?
Klicek ;-)
Master nie widze tu nic smiesznego
Lis - nie wiem powinno dzialac :)
Czesc wszystkim
Tutaj przedstawione jest kilka obrazow pokazujacych efekt shift lens feature. na pierwszym z nich funkcja shift lens on jest wlaczona na drugim efekt kiedy jest ona wylaczona.
trzeci obraz pokazuje mozliwosci nowej opcji - z-clipping, bardzo uzytecznej szczegolnie dla architektow do pokazywania wnetrz budynkow.
Wiem, ze to nie koniecznie sa najlepsze z mozliwych obrazow ale mam nadzieje ze sumuja w prezentacyjny sposob mozliwosc Maxwell Render 1.5
... czym się różni pierwszy obrazek od drugiego?
A to z-clipping to chyba bez problemu można było uzyskać w maxwellu 1.1...
Dobrze, że świat nie jest tak fizycznie poprawny jak ten maxwell, byłoby tak smutno.
Maxwell Render 1.5’s SimuLens™
System pozwala użytkownikowi na wybranie wzoru do naśladowania kształtu przysłony, który ukształtuje wzór światła docierającego do filmu, tworząc realistyczne efekty dyfrakcji na obiektywie (blask słońca). Dyfrakcja następuje gdy światło przechodzi przez niewielkie otworki, powodując mieszane wzroy. Zjawisko to jest bardzo istotne w optyce, wyjaśniając np czemu nie można zbudować idealnego teleskopu. Światło będzie zawszo powodowało zjawisko interferencji ze względu na użyte elementy, powodując wizulalne zjawisko zwane dyfrakcją. Co więcej, z systemem Simulens, użytkownik może dodać kolejny wzór, który zdefiniuje obiekty w obiektywie, takie jak kurz, krople wody, odciski palców czy rzęsy, składając się na bardziej realistyczny efekt dyfrakcji. Do funkcji dyfrakcji obiektywu dodano kolejną opcję, Częstotliwość, która pozwala dopasować efekty kolorów dyfrkacji. Kolejnym nowym dodatkiem do Simulens jest rozproszenie obiektywu, który wzmacnia rozproszenie światła w obiektywie. Ten efekt nazywany jest potocznie rozkwitaniem. Te zaawansowane opcje wprowadzają jakoś grafiki komputerową=ej na nowy, bardziej relaistyczny poziom. Użytkownicy mogą teraz kontrolować częstotliwość dyfrakcji, Rozproszenie obiektywu i symulować efekt rozkwitania. Wszystkie te opcje dostępne są w nowym systemie Simulens który współpraucje także z Multilight. Dyfrakcja może być również zastosowana w obrazach HDR.
Video by Yusuke Okaue:
http://www.maxwellrender.com/forum_ni/bulb_movie_finish.zip
Suuuuper !!! :)
Już nie mogę się doczekać, aż będę miał maxwella 1.5 w łapkach :D
Maxwell Render 1.5 will be released next week (the week starting May 21, 2007). As mentioned before, we want this to be completely ready, with all resources completed, and everything set for release.
Some further, not-mentioned-before features will come with the release, as well as a complete list of bug-fixes and improvements.
Wiec zaczynamy od przyszlego poniedzialku :D
Displacement !!
Funkca displacement w koncu w maxwellu :) lecz nie ukarze wraz z wysjciem 1.5 lecz dopiero za 1-2 miesiace po wyjsciu 1.5 jako darmowe upgrade !!
Kilka testow:
Z-Brush - ja tego nie renderowalem :)
Xizor - o czasach to nic nie wiadomo
hinuds - yes sir :)
Czesc
Dema jeszcze nie ma, powinno byc na dniach wraz z upgradami do pluginow ;)
