Napisano 13 Kwiecień 201510 l Nowe wersja muda- szaleństwo nie do opisania :) Zbrush może już się pakować, pozamiatali chłopaki :D http://www.autodesk.com/products/mudbox/features/new/list-view Sculpting Falloff options – you can now choose Volume or Surface Falloff options for brushes, in addition to the default Hybrid mode. With Volume Falloff, anything within the brush radius will be affected by the brush stroke, regardless of whether surfaces are connected or not. Surface Falloff mode gives you more control by using the center point of the brush to determine the area affected. Relax Brush – use Constrain to Surface in the new Relax Brush to even out spaces between vertices while only making minimal changes to the original shape of a mesh. Twist for Grab Brush – the Twist feature in the Grab tool helps you twist all vertices within the sculpting brush falloff radius clockwise or counterclockwise. Use it to create swirled objects like soft serve ice cream, rotate ears and eyes on a character’s head, etc.
Napisano 13 Kwiecień 201510 l Nowe wersja muda- szaleństwo nie do opisania :) Zbrush może już się pakować, pozamiatali chłopaki uważaj, bo ktoś uwierzy że pisałeś to na poważnie
