witam,
to bedzie troche samolubne bo w sumie moge sobie sam poszukac, ale....
czy znacie jakis bardzo dobru tutorial do Adobe After Effects 6.5
, ale nie tutoriale,,,,,,,,, tylko tutoriale ktore wiele wam pokazaly i nauczyle, - wiecie kazdy ma takich kilka ktore otworzyly mu oczy, - byly bardzo pomocne - help pleas. - z gory dzieki. pa
  • Odpowiedzi 15
  • Wyświetleń 25,6k
http://www.stephenschleicher.com/htm/tutorialsaftereffects.html
http://www.creativecow.net/articles/aftereffects.html
http://www.creativecow.net/tutorials.html
http://aftereffects.digitalmedianet.com/
http://www.stevengotz.com/tutorials.htm
http://www.tutorialfind.com/
http://www.toolfarm.com/tutorials/#ae
http://www.pixel2life.com/twodded/c_adobe_after_effects_tutorials/
http://www.ayatoweb.com/ae_tips_e.html
http://www.graymachine.com/tutorials.html
http://www.layersmagazine.com/video/index.php
http://www.trapcode-people.net/index.php
http://homepage.mac.com/komaruyama/Tutorials/AE/
http://hotwired.lycos.com/webmonkey/multimedia/animation/
http://kigotix.com/zone/downloads/
http://mfdh.ca/technique/
http://msp.sfsu.edu/instructors/rey/aepage/tutorials.html
http://technology.communication.utexas.edu/dv/2_editing.html#ae
http://voir.mylenium.de/creation/ae_index.html
http://www.adobe.com/products/tips/aftereffects.html
http://www.angie.abel.co.uk/tutorials.htm
http://www.artworld.si/after_effects-tutorials-17.art
http://www.creativemac.com/HTM/Sections/Tutorials/tutorials.htm
http://www.designertoday.com/tabindex-1/tabid-41/DesktopDefault.aspx
http://www.digitalmediatraining.com/zoomin/tutorials/index.html
http://www.digitaltutors.com/digital_tutors/video_category.php?vcat=ae
http://www.durbnpoisn.com/films/index.asp
http://www.forge.net/tuts.htm
http://www.geocities.com/pixelmagic2002/CineAltaMotion.html
http://www.happygraphics.net/friendlysite.html#goodies
http://www.layerlab.com/default.aspx
http://www.motionworks.com.au/tutorials/tutorials_01.htm
http://www.outlawfx.com/tutorials.html
http://www.pacific.adobe.com/products/tips/aftereffects.html
http://www.reidroberts.com/aeprojects/
http://www.shumways.net/n/html/article.php?sid=38
http://www.studio5video.com/tutorials.htm
http://www.theforce.net/fanfilms/tutorials.asp
http://www.thoughtography.net.au/students/afterEffects/index.htm
http://www.videocopilot.net/tutorials.html
http://www.wondertouch.com/tutorials.asp
http://www.xtreme-is-back.com/index.html
https://www.walkereffects.com/support/examples/
http://www.dv.com/columns/motion_graphics.jhtml
Mi help otworzył oczy. Poważnie. Przerobiłem kilka tutoriali z ayatoweb i creativecow ale z helpa dowiedziałem się najwięcej. Jest ładnie napisany.
Witajcie. Właśnie stałem się użytkownikiem Adobe After Effects 2.0, i jednoznacznie jestem gotów stwierdzić, że to żałosny badziew, a jeśli ktokolwiek zmontował na tym bez najmniejszej przeszkody hcociaż jeden film dłuższy niż chćby piętnaście minut, powinien zostać nagrodzony noblem albo oscarem. Przykro mi to pisać, ale nawet 3ds max, który ma wady wyprowadzające z równowagi, ale to cudo Adobe, czepia się czegoś na dosłownie każdym kroku, błędy i alarmy pojawiają się przy każdym praktycznie momencie pracy, przy eksportowaniu, przy importowaniu, i przy innych funkcjach, co jest NIEDORZECZNE, i ostatecznie stwierdziłem, że jest to eghmm.. przeokrutny badziew. Jenua.WrrrrrrrrRrrrrrr
Primo AE nie służy do montażu, tylko do postrodukcji, do montażu to masz Premiere. Poza tym 2.0 ? To chyba jeszcze z epoki DOS'a łupanego... give me a breake...
Jak robisz głupoty, to się czepia. Zresztą taki antyk to pewnie pewnie będzie miał problemy z obsługą nowego sprzętu i systemu (choc nie wiem co tam masz).
Ja tam nie twierdze, że AE jest idealny itd, ale Wiget5 - pieprzysz głupoty...
Poza tym to nie jest wątek do wylewania żali, tylko do tworzenia bazy tutoriali...
noo i ?...
Dwa-Zero? Z ktorej to epoki?
W dodatku filmy sie montuje raczej w premiere.
Witajcie. Właśnie stałem się użytkownikiem Adobe After Effects 2.0, i jednoznacznie jestem gotów stwierdzić, że to żałosny badziew...
Witaj, właśnie przeczytałem Twojego posta i jednoznacznie jestem gotów stwierdzić, że nie ogarniasz do czego służy ten soft. To tak jakbyś używał Excela, jako edytor tekstów.
No racja, w Adobe After Effect nie da się tworzyć filmu od podstaw. Ale jak chciałem zapytać (też jestem w tym póki co zielony) jak wygląda taka praca z tym programem. Np. Montuję film w Adobe Premier Elements, potem wycinam z niego te części, w których chcę nałożyć jakiś efekt specjalny - wrzucam je do After Effect, obrabiam a potem z powrotem do Premier Elements w celu zespolenia z resztą filmu?? dobrze to rozumie?
No mniej więcej :) Do AE wczytujesz klipy do obróbki, robisz co masz zrobić, renderujesz do pliku i to wstawiasz do Premiera. To taki podstawowy workflow, ale między Premierem i AE działa takie coś jak DynamicLink, czyli możesz klipy pocięte w premierze skopiować przez schowek do AE, dodatkowo możesz w jednym i drugim umieszczać kompozycje z drugiego programu - np. obrabiasz wideo w AE, kopiujesz gotową kompozycję do Premiera i podczas renderingu finalnego klipu z Premiera on w tle uruchomi kopię AE do przeliczenia tego - przy czym trzeba pamiętać, że wydajność takiego rozwiązania będzie niższa od wcześniejszego przerenderowania do pliku bezpośrednio z AE.
No i niestety z Premiere Elements to nie zadziała, bo DynamicLink jest dostępny tylko jako część pakietów CS.
tak na marginesie chciałem jeszcze zapytać: Czy Adobe Premiere Elements 4.0 wiele się różni od wersji 7.0?
P.S I dzięki za wcześniejszą odpowiedź;)
Oczywiście, że da się robić filmi od podstaw. Takie cudo nazywa się potem Motion Graphics bo w całości składa się z wektorów albo zdjęć. Ale nie polecam robienie czegokolwiek dłuższego niż 1,5-2 min chyba, że sama koncepcja tego wymaga.
