Właśnie zainstalowałem nowego vraya 2.40.01
Z nowości które dla mnie są ok to target dla vray lighta :) nareszczie
New features:
(*) VRayHairFarmMod: Added support for rendering HairFarm 2.0 with V-Ray;
(*) VRayProxy: Support for Alembic .abc files;
(*) V-Ray RT: Support for instancing;
(*) V-Ray RT: Support for Forest Pro instancing;
(*) V-Ray RT CPU: Faster update when adjusting VRayLights;
(*) V-Ray RT GPU: CUDA speed optimizations and optimizations for GK110 cards;
(*) V-Ray RT GPU: Support for the ColorCorrection texture;
(*) V-Ray RT GPU: Support for the Mix texture;
Modified features:
(*) V-Ray: Added include/exclude object lists for different color channels to the MultiMatte render element;
(*) V-Ray: Added option to the VRayExtraTex render element to avoid auto-renaming the element when the texture is changed;
(*) V-Ray: Default memory limit for dynamic geometry changed to 4000 MB for x64 versions;
(*) V-Ray: Fixed issue that was slowing down multi-core rendering for VRayProxy objects;
(*) V-Ray: Optimized multi-core rendering for OpenEXR textures;
(*) V-Ray: Optimized unnecessary velocity calculations when no velocity channel is needed;
(*) V-Ray: V-Ray components now register in the respective menus across different language 3ds Max builds;
(*) V-Ray RT CPU: Added support for VRayHairMtl;
(*) V-Ray RT CPU: Added support for VRayFur;
(*) V-Ray scene converter: Added mr_Sun/mr_Sky lights in export to VRaySun/VRaySky respectively;
(*) V-Ray scene exporter: Added subdivided geometry export;
(*) VRayEdgesTex: Improved the round corners algorithm;
(*) VRayAmbientLight: Made some of the parameters animated;
(*) VRayFur: Added "Level Of Detail" option to reduce geometry along the distance from the camera;
(*) VRayHDRI: Added "Color space" section and moved the "Gamma" option there;
(*) VRayIESLight: Added an option to override the IES shape;
(*) VRayIESLight: Made selecting both the light and it's target when clicking on the line between them;
(*) VRayLight: Added a preview of the "directionality" parameter of VRayLights in the viewports;
(*) VRayLight: Added "targeted" option for rectangle VRayLights;
(*) VRayLight/VRayIESLight: Added textured lighting in Nitrous viewport, for Dome light enabled by an environment variable VRAY_DOME_VIEWPORT=1;
(*) VRayMeshGeom: The sample plugin was extended to create V-Ray Standalone shaders on the fly;
(*) VRayMtl: Made "Fog color" mappable;
(*) VRayMtl: Made reflections to affect the alpha of matte objects;
(*) VRayMtlGLSL: Added ability to save and load compiled shaders;
(*) VRayMtlGLSL: Added cubemap texture support;
(*) VRayMtlGLSL: Added viewport color parameter;
(*) VRayMtlGLSL: Added vr_brdf_light builtin BRDF support;
(*) VRayProxy: Support for flipping of Z/Y axis;
(*) VRayProxy: Support for visibility lists for .vrmesh and .abc files;
(*) VRaySphereFade: Added support for box and cylinder gizmos;
(*) ply2vrmesh: Added option to specify the name of the velocity attribute (-velocityAttrName);
(*) ply2vrmesh: Added support for .hclassic and .bhclassic files produced by Houdini 12;
(*) ply2vrmesh: Added support for color sets from .bgeo files;
(*) ply2vrmesh: Added support for exporting the face and vertex normals in .geo and .bgeo files;
(*) ply2vrmesh: Added ability to store the V-Ray user attributes when creating a proxy;
  • Wyświetleń 7,6k
Obiekty Proxy ze zwiększoną skalą zmieniają mi położenie w scenie. Trzeba wrócić do starej w wersji... :/
Dokładnie, teraz już chyba nie ma żadnego argumentu za stosowaniem tradycyjnych IESów :)
(*) VRayMtl: Made reflections to affect the alpha of matte objects - Jak dla mnie to mniam!
