Cinema4D R11
Dla zainteresowanych, dzisiaj ukazała się nowa wersja programu Cinema4D.
Najważniejsze dodane funkcje (sorry, za brak tłumaczenia):
- Non-Linear Animation
Move beyond the keyframe. Animation Layers and Motion Clips tools let users easily build, layer and loop discreet motions containing hundreds of keyframes in complex hierarchies.
- Completely New Global Illumination
Take advantage of the most current algorithms and computer hardware with the all new easy to use Global Illumination engine. This technology delivers heightened flexibility to achieve ultra-realistic results with a minimum of setup time, even for animations.
- BodyPaint 3D
New tools for painting rich, detailed textures onto a 3D model as well as an improved workflow are part of this major upgrade to the popular 3D painting application. The improvements facilitate even tighter integration into industry-standard painting pipelines with brush import, WACOM tablet support, PSD format enhancement and more.
- Improved Rendering Speeds
Tremendous optimizations in multithreading and CPU efficiency offer dramatically improved rendering speeds. Overall render quality has been greatly enhanced as well. New parameters make it possible to create even more realistic glass materials.
- Support for 64-bit on Mac OS X
CINEMA 4D R11 is the first comprehensive 3D package completely re-engineered to take full advantage of the Mac OS X 10.5 release. As a native 64-bit Cocoa application, CINEMA 4D can be used in 64-bit mode to utilize greater RAM resources so you can build and render more complex projects. All 64-bit processors are supported. Users can easily switch between 32-bit and 64-bit mode to suit their individual needs.
- Projection Man
Leverage the same powerful matte painting system originally developed by MAXON exclusively for Sony Pictures Imageworks and recently used to create such blockbuster features as Hancock, Speed Racer, Beowulf and Surf's Up. This formerly exclusive toolset enhances workflow and makes it easy to create and patch the mattes. Tight integration with Adobe Photoshop and MAXON BodyPaint 3D simplifies editing and manipulating extensive digital mattes and even fully immersive 3D environments.
- CineMan
Power users can easily render CINEMA 4D projects utilizing Pixar's RenderMan Pro Server, or other RenderMan-compliant engines including 3Delight (dna research) and AIR (SiTex Graphics) through support for the RIB format.
- COLLADA Support
R11 now supports COLLADA, an open standard XML-based format that facilitates the transfer of 3D assets between applications. Exchanging scenes with other 3D applications is now easier than ever for diverse Digital Content Creation (DCC) production pipelines.
Ogólnie o wszystkim można przeczytać na stronie Maxona
http://www.maxon.net/pages/products/new_e.html
Aha, jest już wersja demo do ściągnięcia.
pozdrawiam,
makak_
  • Odpowiedzi 8
  • Wyświetleń 3,1k
o (cze)COLLADA nawet jest :D
a w XSI są lody :) sorry musiałem :P
BodyPaint R4 nawet ciekawie wygląda ale pewnie nadal ma pierdołowaty (czyt. nie fikołek freandly ) viewport :)
Używam Cinemy od. R 9.6 i każdy up przynosi dużo dobrych rzeczy. Tym razem chyba największa radość z nowego renderera.
Zdecydowanie przegapiles... Na moje oko to wersje 10 i 10.5 ;)
Google it.
no tak R10 i pochodne są w cenniku a na stronie informacje o wersji 9.6 (że nie wspomnę o tym że można sobie poczytać o nowościach w wersji 9.1)- straszny bałagan mają na stronie (wersja polska)
no racja, polska oficjalna strona cinemy jest dosć zacofana co do nowości i ktoś się z naszych nie przykłada ;)
