Nowy Wings3d 0.98.36 yes yes yes
Hej
Wlasnie oficjalnie pojawila sie nowa wersja wingsa3d oznaczona numerkiem 0.98.36, baaaaaaaaaardzo duzo zmian, nowy ikonki szkoda ze nie nowy lajout ale kij ;)
Nowe opcje dzialaja genialnie ;) , duzo nowych prymitywow sie pojawilo , no i do tego unfold dziala jeszcze lepiej :)
link :
http://www.wings3d.com
Lista zmian :
Release Name: 0.98.36
Notes:
- Absolute snap now can pick reference point, old snap that used center of
selection as reference point was moved to MMB option. [Giniu]
- Added new preference: constrain axes to grid. [scorpius]
- Added "Blue Cube" interface icons. The original icons are in the "Classic"
bundle. Switching between icon sets is easily accomplished through the
User Interface preference tab. [scorpius]
- Revived the Plane Plugin, which was removed from a previous release
because it created invalid objects. This has been fixed by adding a
thickness parameter; thereby creating a properly closed mesh. [scorpius]
- Added two new primitives (look under the More menu):
Tube: generates a hollow tube or pipe with an actual wall-thickness.
Gear: generates a very simple gear. Allows the user to specify the number
of teeth and the tooth height. [scorpius]
- Added two more primitives:
Ncube: Generates a cube with an arbitrary level of subdivisions (simply
specify the number of cuts per edge) plus a spherize option.
Ngon: Generates a polygon with an arbitrary number of vertices. This may
look like a single-sided polygon but, in fact, has two faces. [scorpius]
- New GeoDome primitive. Generates a geodesic dome with an arbitrary level
of subdivisions. Has three base objects, spherize and half-dome options.
[scorpius]
- New *.stl import/export plugin. Stereolithography files can be sent to
a service bureau to create an actual plastic prototype of your model.
[scorpius]
- New command in tools menu: "Scene Info: Area & Volume." Calculates the
area and volume for each object in the scene and displays the info in
a pop-up window. [scorpius]
- Bug fix: Language support now works for all operating systems, regardless
if the file path has an underscore. [scorpius]
- Added X export plugin.
[contributed by Ed Kolis (Ekolis)]
- New command in tools menu: "Put on Ground." It simply moves the selected
objects vertically until they rest on the ground plane. [scorpius]
- Added "Purple Tube" interface icons. Check the User Interface preference
tab to switch between icon sets. [scorpius]
- New commands in 'Select->By' menu: "Fewest Edges Path" selects a path
(between any two selected vertices) with the fewest number of edges.
"Shortest Path" selects a path with the shortest distance. If more than one
possible solution exists, the first one found will be selected. [scorpius]
- New secondary mode for dissolve, called clean dissolve.
[contributed by Richard Jones (Optigon)]
- Added ability to set alternate zoom speed, check camera preferences.
- Tweak tool extended with new features like tangent, relax, slide and more.
[contributed by Andrew Shpagin (AndrewShpagin)]
- French translation updated, with many more plug-ins translated.
[contributed by Nicolas Bouillard (syndarion)]
- The Mac version of Wings is now a Universal Binary that runs on both
PowerPC and Intel Macs. [bjorng]
- The Windows version now includes the correct (latest) version of the
SDL dll, correcting numerous problems. [bjorng]
  • Odpowiedzi 26
  • Wyświetleń 3,5k
Dzięki za info, jest klika ciekawych zmian i bajerków :)
czyli Klicek przez cała zimę nie wychodzi z domu :D
good news compadre :)
Purpurowe ikonki? Ja to chce zobaczyc :) A tak by the way, to naprawde fajny ten wings :)
Purporowe ikonki sa fajne ale poprostu jak zobaczylem co zrobili z "tweakiem" to poprostu poczulem sie w niebie :D
Ja już po przeczytaniu na liście zmian poczułem się jak w niebie ;] Jak wrócę do domku to potestuję.
Mimo najszczerszych chęci opanowania tego programu, jego interface mnie poraża swoją niewydajnością... a może to ja już jestem za stary na zmiany. :(
No mi też interfejs nie podszedł i dlatego moja zabawa z Wings'em skończyła sie po godzinie. Ale nowa wersja oznacza kolejną dawkę tutków od Klicka;)
teraz z czystym sumieniem mogę napisać: nowy tweak miażdży :)
Hm, interface jest inny, ale wystarczy poswiecic troche czasu rzeczy poprzerzucac sobie najczesciej urzywane komendy pod klawisze, i mozna pracowac bardzo szybko. Ja teraz na podobnej zasadzie proboje sie zmierzyc z Modo :)
A tutki od klicka zawsze sie przydadzą, nie wazne czy wings czy inna cholera :D
Następny Wings będzie pewnie 0.98.klicek
btw. wiecie może czy on wgrywa file do rejestru? bo w szkole mam instalacje zakazane i nawet próba korupcji nic nie daje...a tak to bym sobie go przyniósł.
Chveti prawdopodobnie wgrywa tylko wtedy cos do rejestru jak zaznaczysz "make default" czyli to zeby odczytywal ikonki wingsowskie ;) pozatym wrzuca pliczek z zapisem wlasnych ustawien do C:\Documents and Settings\XXX\Dane aplikacji\Wings3D\
buheehehehe :D
Remedy - tak naprawde w wingsie nie uzywa sie interfacu tylko skrotow klawiszowych i prawego przycisku myszki:)
jak juz mowilem tweak mnie powolil na kolana i powiedzial "bedziesz ze mnie kozystal jeszcze czesciej"
faaajnie
niech się inne programy idą chować
na stronie głównej jest błąd w tytule, ma być 36 nie 32a
Wiec ktora wersja jest nowsza 32a czy 36? Bo juz sie pogubilem...
ooooh! klicek, ty sobie chyba jaja robisz, przez ciebie nie wyjde z mojego pokoju przez najblizsze 10 lat :/
Fajny ten Wings, Ale na razie niewiele w nim potrafie zrobic. Nie wiem jak sie usuwa w nim poligony :D ktos moze wie jak? I czy jest w nim chamfer? ;]
ja zawsze usuwam polygony opcją hide, a chamfer to opcja bevel :)
Mam pytanie do znawcow Wingsa. Czy ktos wie cz ktores funkcje z pluginow Calcosa sa juz zaimplementowane? Czy sa moze gdzies dostepne uaktualnione wersje dzialajace z nowymi Wings'ami? Z gory dzieki.
Strasznie wolniuchno sie uruchamia, co oni tam upchali:)? ale faktycznie zacny programik, faktycznie tweek jest swietny. a mimo wszystko przydalo by sie jakies boczne zawsze widoczne menu z kilkoma przydatnymi opcjami zawsze na wierzchu, moze jest jakis sposob zeby taki custom toolbar zrobić?
