Paintstorm Studio
Dzieki Ci. Chcialem go wyprobowac bo kupilem jak wielu ale nigdy nie sciagnalem i nie moglem sobie przypomniec nazwy ;)
haha dobre! :D to trochę jak ja z messiahStudio tyle, że nazwę pamiętałem :P
  • Odpowiedzi 104
  • Wyświetleń 46k
Do tej pory licencja mesjasza lezy na moim dysku nietknieta, kek ;)
Właśnie mi przypomnieliście że też kupiłem ten soft. Nigdy nawet nie zainstalowałem. ;)
Tak w ramach przypomnienia dla tych co kupili a zapomnieli ściągnąć i uruchomić :) może tym razem się uda :P
fajne malowanie trawy od 7 minuty :)
VERSION 1.50 (14.11.2015)
- Now you can Import / Export your brushes and brushes groups as well as create new categories of brushes. In this regard, we have made a completely new data structure. That is why the brushes import from older versions Paintstorm (1.41 and below) is impossible. We apologize for this inconvenience. The new version of Paintstorm Studio is created to avoid such things in the future, because now you can save your favorite brushes in a separate file, as well as share your brushes collection with your friends.
- The number of points in the graphs is increased from 10 to 50
- The information about the gradient and the set of is now stored in the brush. So if you change any gradient or set of forms, this will not affect other brushes using them.
- New options added: «import» / «export» / «add» / «remove» for: Brushes, Custom forms, Textures, Brush previews, Category icons, Gradients. You will get the access to the new functions through the mouse right click. Right click works on the following panels: Brushes, Custom forms (single and "set of forms"), Textures, Brush previews, Category Icons, Gradients. (Note: When you create your own sets of brushes, you have to remember that the "erasers" - are the 2nd group and «mixer brushes» (which are used in the «mixer» panel) - are always the first three brushes in the third category) Also, now you can reset all brushes to the default settings at any time.
- The ability to import brushes (brush shapes) in ABR Photoshop format (Note! Abr-files should not contain hairy brushes, appeared in Photoshop CS5)
- The "Capture form" feature added for the brush. Just select any part of the picture and click "Capture form" at the top of the screen. (Or use Menu-> Selection-> Capture form)
- The ability to import / export / reset your workspace (as a whole or separate elements) added. Access to this features: Menu-> Other -> (Load custom UI, Save Custom UI, Reset to Defaults)
- In the brushes display «tiles» mode you can now click the brush with ctrl or shift, to change the display of the brush from brush-icon to brush-shape and vice versa. The same applies to the brushes located in the custom panels.
- Scrolling the list (such as layers or brushes) now works like on your smartphone. Just click anywhere on the list and move the mouse or pen up or down. "Scroll bar" also works, and saved for those who are used to it, but it can be completely disabled in the Menu-> File-> Options-> Enable scroll bars
- The CPU usage reduced
- The gradient settings improved: Now you can right click on any point of the and select "Main color" or "Second color". You can also set an option so that the the gradient point will take only H, S, HS, HB, HSB, etc from the "Main color".
- The texture mapping quality improved
- Some fundamental changes regarding the error handling: Now, in case of a critical error, Paintstorm will not just crash, like before, but also try to save all the open files. Some non-critical errors will be ignored when possible. All the information on the errors will be stored in %userprofile%/Documents/Paintstorm Studio/Logs/ You can send us your the error files. This will help us to detect the causes of the errors and make Paintstorm more stable and safe.
- When you use «Free Transform» of large images, there is an image deterioration at the time of transformation on live in favor of the performance
- Chinese interface added.
Some bugs fixed:
- The size of the panels change when Paintstorm window is minimized.
- The tablet shutdown when «jumping» to other applications.
- The incorrect display of the «Brush direction angle» stripe.
- Tiles on Retina5K.
- When drawing in a «mixer», you could touch the edge of the window and change its size.
- Failure to register without internet connection.
- A lot of of minor bugs.
For MAC Version:
The data structure has undergone great changes. Now Paintstorm, as well as other applications, is installed with the .pkg file directly to «Applications». Brushes and interface settings are stored in ~/Library/Application Support/Paintstorm Studio/
Accordingly, to move the Workspace to the new version the previous one, you have to do the following steps:
1) Install the new version
2) Run it from /Applications/PaintstomStudio.app at least once
3) Copy the "Data" folder from Applications/Paintstorm Studio/Paintstorm Files/ to ~/Library/Application Support/Paintstorm Studio/ with replacement
Moreover, do not forget to change the icon of Paintstorm Studio from "Docs bar"
Edytowane przez Imperator
To co dzieje się na filmiku z kwiatami to jakaś magia. Nawet nie wiedziałem, że tak można. A to mój ulubiony soft. Pozwolę sobie wrzucić co udało mi się namalować ostatnio:
Naprawdę polecam program, silnik mieszania kolorów jest najlepszy z wszystkich programów jakie testowałem (moim zdaniem lepszy niż krita, CPS, PS)
@JoseConseco Kapitalny stworas :D JAki to soft bo napisales "A to moj ulubiony soft" - chodzi o Paintstorma wlasnie czy cos innego?
JoseConseco bardzo fajna pracka :)
olaf ja co roku dopisuję zrzucić parę kilogramów i co roku jest to parę kilogramów więcej niż poprzednio :P
Też zapomniałem że mam ten soft xD ...ale już widzę że się bardziej przyda niż Messiah :P
Rejestrację zrobili po ludzku w końcu, wystarczy maila podać w sofcie i już. Wcześniej trzeba było wysyłać jakieś maile do supportu i czekać na klucze... -_-
Tak PSS. PSS jest właściwie jedynym tanim softem (nie jestem pewien co do PS i CorelPainter) który ma mieszanie kolorów i dostępną opcję 'flow' dla pędzla. Tu na forum krity (drugi obrazek w poście) opisałem jak kiepsko wyglądają pociągnięcia pędzla w silniku mieszającym krity, gdy chcemy uzyskać półprzezroczysty efekt, ale nie mamy dostępnej opcji 'flow' (w rożnych softach inaczej to się nazywa). Dla porównania niżej na trzecim obrazku, w wyżej wymienionym poście, wrzuciłem pociągnięcie pędzla z PSS. Brak artefaktów i ładniej o wiele to wygląda.
Jeśli ktoś jeszcze nie kupił, a chciałby to teraz może być dobry moment, bo z okazji black friday jest obniżka 50%.
Tradycyjnie już przypominam o tej perłce :) nowa wersja, nowa strona, nowa prezentacja :) ale cena stara tj 19$! nie wiem jak oni mogą to nadal za pół darmo rozdawać :)
http://www.paintstormstudio.com/
VERSION 1.55 (22.04.2016)
- A new feature to record/playback the process of drawing called Script added.
Typically, the scripts are used to create videos of a painting process, however with Paintstorm's script it is possible to increase the canvaz size of your pics without any quality loss.
Learn more about Script here: http://paintstormstudio.com/help.html#SCRIPTR
- "Toggle rulers" hotkey added
- "Lock interface" button added (top right corner of the Paintstorm window)
- Some small bugs fixed
VERSION 1.54 (19.03.2016)
- A new «Blur» parameter of the brush added that affects the strength of the paint mixing
- An ability to select layers in Photoshop style from the drop-down list (by default - Mouse Rightclick)
- An ability to move the layer with keyboard arrows added
- An option "Show / Hide brush circle" in Menu-> Options added
- An ability to display the «Thumbnails with layer bounds» added to the options of the "Layers" panel
VERSION 1.53 (01.03.2016)
- New "Ruler" feature added: Parallel lines, Ellipse, 2-point perspective, 3-point perspective
- "Global pen pressure hardness" feature added to Menu-File-Options
- The ability to "Merge all lower layers to one new" added (ctrl+alt+shift+e or from menu)
- The ability to Apply mask added
- A bug of saving PNG with alpha chanel fixed
- "Rename brush" item added to the Brushes options
- The Free Transform option moved to Menu-Edit from Menu-Image
- New interface language added:French (Thanks to Siron Jean for translation)
VERSION 1.52 (07.02.2016)
- The new "Real Double brush" feature added. Now you can paint with two brushes simultaneously instead of using the second brush only as a mask. You can also synchronize main parameters of both brushes.
- We added the ability to shift the pivot point for custom forms. It is also possible to reflect the shape vertically or horizontally and rotate at any angle.
- New buttons added to the top «Tool options» panel: free transform, disable selection, chain for rect selection and free transform, etc.
- Now, when you close the last file, Paintstorm creates a blank canvas without shutting down.
- Instead of "rightclick" an additional button added to the following panels: Gradients, Textures, Brush icons, Brush Group icons, Custom Forms.
- «Move the layer up / down» buttons added to the «Layers» panel
- Presets added to the File->New panel
file.php?id=114
file.php?id=111
[video=youtube;D-yj-RqTyUc]
Kolejny raz przypominam tym co kupili i nie używają :)
W wersji 1.7 dodali jedną przydatną funkcje - można transformować lub "liquifajować" wiele warstw lub zaznaczonych fragmentów z warstw jednocześnie, to o jedną przydatną funkcję więcej niż adobe dodało w nowym photoshopie :D
[video=youtube;Fa455Pd-VyA]
VERSION 1.71 (16.10.2016) - HOT FIX
- Fixed an issues and bugs of version 1.70
- New "Fast layer move" hotkey added
- New "Show\hide reference layer" hotkey added
VERSION 1.70 (12.10.2016)
- An ability to select multiple layers and do the followings with them added:
layers move, free transform, swap layers, delete layers, collapse layers, delete selection, preserve opacity, lock, warp filter.
- A new Warp filter added
- New types of gradients added: radial, symmetry, circle
- Flip horizontal / vertical layers functions added (Menu->Edit)
- An ability to enable / disable the link (chain) between the layer and mask
- Added a function of layer duplication by holding Alt
- Added the ability to move the layer while holding Ctrl
The following bugs fixed:
- An burn effect at low transparency fixed
- A bug of trembling form when "form shift" fixed
- A bit of memory is released at the time of saving / loading psd
- A "lock of transparent pixels when blend transparency is on" bug fixed
- Some minor bugs fixed
VERSION 1.61 (24.08.2016)
- «Select by color range» function added. With this accurate tool you can easily select a specified color or the range of color and brightness.
- Improved quality and accuracy of "Free transform" and "Image resize" tools
- Improved quality of selection edges when using "Straight lasso" tool
- Some little bugs fixed
VERSION 1.60 (18.05.2016)
- The "Clone" tool added. Find the button close to the "Eraser" button in the "Brush" panel.
- The cursor shape changed: now it has the same shape as the brush instead of the circle.
- A new "Resolution (dpi)" option added to the following panels: "New file", "Image resize" and "Canvas size". The dpi value is now saved in PSD files.
- A new "Filters " section added to the menu . This section contains two filters - "Blur" and "Sharpen".
- The active box to control the position of the canvas added to the "Navigator" panel.
[video=youtube;cbUW7pCu-b4]
Nie za pół darmo tylko za darmo, bo płącisz raz na całe życie. A 19 baksów i i gimnazjalista wydłubie od starcyh ;)
Aż mnie korci żeby to sobie kupić i nie używać :P Tak zrobiłem z Mischief i to był strzał kulą w płot. Po za pierwszymi ochami, achami i ojeku, soft został przeze mnie zapomniany, jak równiż przez developerów.
Ale ten wygląda bombowo, z każdą wersją! Na razie siedzę przy Kricie a wątek obserwuję.
O nie widzialem, ze tak preznie promujesz ten kapitalny sofcik tutaj ;) Ostatnio zassalem sobie od nich zestaw brushy udajacych olowki i jestem zachwycony. Lepiej to mi tylko normalne olowki "dzialaja" :D Bardzo sie ciesze ze kiedys skozystalem z tej promocji i kupilem za pare groszy to cacko! Dzieki za linki do filmikow!
Dobra, namówiliścnie mnie. Zgłoścnie się do nich po prowizje.
Nie wiecie o co chodzi w Paintstorm Studio
SPECIAL PRICE
FOR THE FIRST 1000 ARTISTS
SPECIAL PRICE
Ta, dalej ta sama, promocyjna cena jest, choc przypuszczam, ze juz dawno sprzedal wiecej niz 1000 kopii ;) Nie zastanawiaj sie, jak lubisz soft do digital paintingu to sie nie zawiedziesz.
O nie widzialem, ze tak preznie promujesz ten kapitalny sofcik tutaj ;) ...
Trzeba ludziom przypominać, że są całkiem przyjemne alternatywy zwłaszcza za tak małe pieniądze :) Poza tym gdybym sam nie był tak bardzo zadowolony z painstorma to bym o nim nie trąbił a o niewielu softach mogę to powiedzieć, chyba najlepiej wydane 19 dolców w życiu nawet gdyby mieli już przestać go rozwijać :)
Jest super. Idealnie współpracuje z wacomem, bardzo dynamiczne i płynne UI. Myślę, że to jeden z najprzyjemniejszych softów jakie widziałem. Daje podobne wrażenie jak porówannie działania Afiniti Designera do illustratora lub ColrelDrawa (mówię o płynności działąnia)
Jeśli ktoś maluje a się zastanawia to polecem.
Mam nadziję, że zapracowałem na swoje ołówki :P
Imperator - rok temu pokazałeś ten soft na forum, dzisiaj kupiłem:) mam nadzieję ze chociaż raz użyję. Ten soft ma ogromne możliwości...obejrzałem tutki, przejrzałem forum - nie było co zwlekać:) dzięki!
Juz taniej byc nie moze chyba :D Swietny soft za na prawde niewielkie pieniadze. I update'y za free.
Dla samego warpa warto kupić, nawet prostą pierdołę jak chcę zwarpować to przerzucam warstwy z photoshopa bo photoshop sobie nie radzi, o bardziej wymagających zadaniach nawet nie ma co wspominać :)
Niedawno wyszła nowa wersja, zmiana numeryczna bardzo niewielka ale zmiany całkiem niezłe, rozbudowana korekcja kolorów, przypisywania gradientów do barwy, nasycenia czy jasności i malowanie zapętlonych tekstur, świetne narzędzia za tak małe pieniądze :)
VERSION 1.72 (05.12.2016)
- "Smart Color Correction" filter added. This is a great set of tools for image editing,
which includes: RGB / HSL / HSB curves, Selective Color, gradient map and a lot of other cool features
- A new "Seamless mode" feature added which can be used for creating seamless textures and patterns.
Seamless mode is supported by all the brushes as well as the free transform tool (ctrl + t)
Enable this mode through Menu-> Edit-> Seamless mode
- Using gradient became a little more comfortable
- Two new Clone modes added. To select a new mode, switch on the brush option "Clone",
and then go to the "Clone modes:" on the top panel
- "Close the current document" hotkey added ("ctrl + w" by default)
nikola-radovic-uptograves.jpg?1480428098
[video=youtube;bS3pbVvEE-Y]
Testowałem te ołówki o których wspominał Nezumi i są naprawdę świetne -po raz pierwszy miałem to poczucie kontroli jakie dają tylko naturalne media ! ( Zaraz na drugim miejscu są ołówki z MyPaint)Pędzle olejne czy akryle też super ale o nich nie wspominam bo je już wiele programów potrafi całkiem sprawnie imitować...
naprawde podziwiam takich ludzi jak tworca tego softu
Pelna zgoda - niesamowicie lekki, niesamowicie szybki. Na prawde nie wiem co ludzie jeszcze robia na PSie. Sila przyzwyczajenia.
wow niby malutki drobiazg ale próżno czegoś takiego szukać w photoshopie :) fajnie się rozwija ten sofcik :)
Juz nie uzywam shopa ale czy czasami nie wystarczylo wcisnac ctrl+t a potem z ctrl wcisnietym przesuwac wierzcholki? Tym niemniej fajny dodatek do Paint Storma.
Tak da się niezależnie punkty kontrolować z wciśniętym ctrl i deformować zaznaczony element ale nie można tego zaznaczenia zmodyfikować przed wszelkimi transformacjami. Możesz jeszcze zrobić inteligiętne obiekty i one zachowują transformacje i jakoś to działa, ale nie można tego edytować i trzeba planować z wyprzedzeniem a tutaj w paintstormie nie masz takich ograniczeń, narzędzie o klasę wyżej od staruszka ps-a no ale w painstorimie nie przygotujesz modelu pod druk 3D wiec ps ma jeszcze asy w rękawie :D
Hahahaha :D A jeszcze jak dodadza sterowanie glosem w PSie to dopiero bedzie sie dzialo :D. Ciekawe czy dodadza kiedys symetrie - juz apki na telefony to maja a "industry standard" nie.
Update
VERSION 2.03 (29.09.2017)
- Added features: Duplicate folder, Ungroup folder, Merge folder, Group layers to the folder
- Using "Guides" And "Rulers" has become much more convenient: Paintstorm now keeps the position of the guides after each move. Click two times holding Shift to install the ruler to the desired direction quickly. For the 2-point and 3-point perspective there is an additional manual direction determination mode.
- A new "Color Library" panel added. Colors can now be broken down into categories (folders), renamed, saved and uploaded. You can also import color sets from Photoshop. You can enable the new panel by: Menu-> View-> Color Library
- A lot of new hotkeys added: Panels toggle, Rulers hotkeys, etc.
- "Show recent colors" option added to the “Color” panel
- You can now save and load your own custom presets of documents size in the "File-> New" panel
- The layer mask can now be dragged from one layer to another one
Dzięki ludzie, ten program jest fantastyczny!
Edytowane przez SBT77
Ja czasem używam do szybkich szkiców zwykłą myszką jak szukam kolorów czy kształtu. Genialny soft. Posiadam chyba od wersji poniżej 1.5. Koncepciarzy i design-mejkerow zachęcam do spróbowania tego softu. Jest ultra szybki.
To macie jeszcze na zachętę jak kolo maluje w Paintstormie.
[video=youtube;Eh1UIA9ij-w]
Jeszcze pytanko. Czy wam też czasem szwankuje tablet? Tak jakby program myśli, że dotykam piórkiem tableta i pociąga pędzlem, przesówa menusy itp..
Nie wiem czy to grafika czy to może tablet. W każdym innym sofcie jest ok.
Intous 5, radeon.
Na obronę PSa - zresztą sam wiesz... W "industry" to chyba coraz mniej chodzi o malowanie, a bardziej o efekt. Inaczej - malowanie cyfrowe to tylko narzędzie, podobnie jak klejenie fot, 3d czy czegokolwiek innego. PS do mixed media czy photo bashy jest zdecydowanie lepszy. Efekt, wg. standardów rynku i oczekiwań graczy/czytelników kupujących po okładce/widzów - też.
Nie ma sensu porównywać softu do malowania cyfrowego z wszechstronnym programem graficznym jakim jest PS.
Trochę porównujemy gruszkę z pietruszką.
Jest sens zawsze robić sobie listę życzeń do softów, których się używa. Ja taką mam, głównie do ZB, trzymam pod poduszką i dopisuję, rzadko coś wykreślam ;)
Black Friday flash sale
-50% OFF!
(10$ for 1 license)
(15$ for 2 licenses)
(6.99$ for iPad version)
Kurcze własnie na nim machnałem 1 zlecenie ... kurde masakra jak ten soft jest szybki i kompletny :) Co wiecej developer mi pisal ze zbliża sie updade wiekszy niz wszystko co bylo do tej pory . Serce mi sie raduje ze moge kopnac addobe w dup**
Dla mnie to była miłość od pierwszego wejrzenia;)
Ale w szarej rzeczywistości jakoś nie podchodzi. Może to ten napakowany interface. Problemy ze "znikającą" licencją. Trochę buggów. Mało opcji przy warstwach.
Już dawno go odstawiłem niestety. Jakoś wolę już chyba Kritę w takich sprawach.
No ale zaciekawiłeś mnie typ updatem. Chętnie dam drugą szansę ;)
A testowałeś choćby najnowsza wersje ? MI ani razu nei zcrashował , ani problemowo z licencja a UI teraz jest mega latwy do customizacj wiec ja w sumie mam tylko warstyw i kolory w stalych oknach . No co do warstw etc nie ma szału ale jest layer mask i cliiping layer wiec dla mnie wystarczy :D
Mnie wlasnie krita odstraszyął crashami i lagami na warstwach przy wiekszych plikach, dziwne odsiwezanie etc ;/ bo sam soft bardzo mi sie podoba tez .
W sumie chyba miałem najnowszą lae usunięta bo co chwilę licencję mi wywalało. Czasem musiałem prosić mailowo o dezaktywację, żebym mógł od nowa aktywować.. Trzeba było chyba blokować dostęp do sieci Paintstormowi. Zniechęciło mnie to troszku.
https://80.lv/articles/paintstorm-artistic-alternative-to-photoshop/
[video=youtube;ynaYNPmRs-A]
VERSION 2.30 (04.06.2018)
- Panels can now be moved outside of the main window (MS Windows only)
- Panels can now be grouped to each other (To do this, drag one panel to the top of another one)
- Added the ability to change the background color (Menu-> File-> New or Menu-> Image-> Document properties)
More features to work with textures:
- The maximum brush texture size is increased to 4000
- Textures can now be renamed and moved
- Added more than 20 new textures
- The «Texture brightness» slider added and the «Texture contrast» slider now works in both directions
- Added the «Mirrored repeat» tick for better display of not seamless textures
- Now you can choose which brush parameter is affected by the texture: opacity, transparency, color, or all together at once
- Fixed some little bugs
VERSION 2.31 (15.10.2018)
- You can now import the colored textures. By the way, the textures do not have to be square anymore
- You can choose several textures at once that are going to change after each new brush stroke
- The "Fill tool" improved. You can switch to Pattern mode for shading. Color mode and Opacity properties added as well
- New "Convert Luma to alpha-channel" filter added
- "Flip horizontally“ button added to the editing of graphs
- If you hold the hot key for more than a second, then releasing it will now return to the previous tool
- ”DragAndDrop” and ”Place Image” now work for multiple files
AAA musze dopisać do listy rzeczy do instalacji. Zakochuje się w tym sofcie z daleka, czas zrobić pierwszy krok ;)
