Jump to content
deshu
3dsmax 2020.2
Recommended Posts
Ciekawą rzecz pisze Pan Dylan Neill w drugim komentarzu:
"Whats slowing Houdini down is the normal re-calucation. If you add a normal node before the bend, set it to points, crank the angle up to 180. Then turn off "Recompute affected normals" and "Preserve normal length" in the bend node then you should get similar performance to Max. I go from 5fps to 18fps with the same model. Not so obvious I know, thats Houdini for you. Maybe Max is doing something similar under the hood or maybe normal recalculation is done on the GPU or something."
Prawdopodobnie w większości softów udało by się to samo gdyby mieć możliwość kontroli nad tymi obliczeniami.
Share this post
Link to post
Share on other sites
sądząc po dalszym ciągu to chyba nie do końca :
Thanks for the tips! Doing so indeed speed up a little. With this It oscillates between 5 and 6 fps on my machine (Im on a laptop). Max still gets 2X more performance.
Należy być wdzięcznym Autodeskowi, pokazują innym developerom drogę...
Edited by Arturborubar
Share this post
Link to post
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
Important Information
